Briggs Model Q Teardown
this thread has 37 replies and has been viewed 1210 times
Old 06-11-2019, 08:09:51 PM
Mike Stroz Mike Stroz is offline
Default Briggs Model Q Teardown
Just picked up a pretty nice Briggs Model Q, serial number in the 5000's, and it seems like it's been sitting so long it's rusted up inside. It turns over but it's a little crunchy. Never seen a Q before, what's the procedure to get it apart? I can see the base unbolts but I haven't done anything but pull the head to reveal some somewhat crusty valves
Old 06-11-2019, 09:03:52 PM
uglyblue66 uglyblue66 is online now
Default Re: Briggs Model Q Teardown
I have a rough but fairly complete Q.The flywheel was run loose and ruined the flywheel and crank.I have only got a glimpse of it in the past 10 years as it is on a shelf in behind a couple B's and some other stuff.
I had no idea they were scarce when I paid 75 bucks for it 20 years ago.I thought I could scratch up a crank and flywheel easy and cheap. I have not looked that hard but have not seen any just laying around.
Old 06-11-2019, 09:21:08 PM
I can imagine parts are hard to come by. This one seems to be in good shape which is why I'm even trying to save it. The cam isn't wiped out and it has good compression. I'm thinking it was just stored in a humid place for a bunch of years without any oil circulating to keep the rust at bay.
Old 06-11-2019, 09:50:45 PM
How bad are the flywheel and crank? I'd think a repair could be effected. Even if it means machining a tapered sleeve...
That's pretty cool. I don't have anything that rare. Some ZZs, a B, a WMB. Do have a water cooled Z / ZZ that's pretty neat
Old 06-11-2019, 10:06:37 PM
Not meaning to highjack but it is my K I would really like to get running.It is close but never hit a lick.
I don't know when I will get time in the near future to dig that Q out. Maybe I should.
Old 06-11-2019, 10:52:24 PM
K-Tron K-Tron is offline
With any valuable, rare old engine, it is best to be as gentle as you can with disassembly. I have submerged many stuck engines in my ultrasonic cleaner and pulled out clean free engines. This process strips paint, so it may not be for you. I'd suggest using plenty of pblaster or kroil to help you disassemble the engine for proper inspection. I would not run an engine of that age without first pulling the piston and rod to check for stuck rings.
Model 82 Teardown Question kleinkaliber Maytag Engines and Collectibles 2 12-06-2015 12:52:25 PM
Little crawler teardown wilson Ross Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-26-2010 01:09:21 PM
Cam timing after teardown gruby26 Small Air Cooled Gasoline Engines 3 01-18-2009 09:21:11 AM
Tecumseh H30 teardown and overhaul squarend Small Air Cooled Gasoline Engines 9 05-10-2008 11:35:27 PM
