Economy With Mill
this thread has 5 replies and has been viewed 626 times
Old 08-09-2019, 12:51:11 PM
AKMark AKMark is offline
Default Economy With Mill
I bought this mill and with engines and hauled the first one home yesterday. I believe the engine is an Economy. It's been converted to spark plug and carburetor. I think this machine is for splitting fence rails but the previous owner modified it for some other purpose. I was told that he made gates for split rail fence. There are 3 other machines that I need to pull out of the barn. There are 2 more engines, a Fairbanks morse model h and a David Bradley.
ID:	341088   Click image for larger version
ID:	341089   Click image for larger version
ID:	341090   Click image for larger version
The Following 4 Users Say Thank You to AKMark For This Post:
Old 08-09-2019, 03:03:59 PM
Default Re: Economy with mill
A few more.
ID:	341092   Click image for larger version
ID:	341093   Click image for larger version
The Following 3 Users Say Thank You to AKMark For This Post:
Old 08-09-2019, 03:48:22 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
HI Mark,
Congratulations. The engine is an Economy and looks to be a 5 HP Model E. it is probably an earlier one because is has the flywheels with the counter weight added to the flywheel rim. later ones had a hollowed out area on the inside of the flywheel rim.
Your engine could of been equipped with a battery ignitor or most likely a Webster set up.
Looks like you will be looking for a carbureter/milxer as well. They are relatively easy to find or you could substitute a Lunknheimer or equivalent mixer.
Joel
The Following User Says Thank You to Joel Mosley For This Post:
Old 08-09-2019, 04:41:14 PM
Joel to be honest I may leave it the way it is, he made the trip using the fuel pump linkage and I think it's pretty Cool job.
After further inspection I guess he made the linkage, as far as I know they didn't have a fuel pump.
The Following User Says Thank You to AKMark For This Post:
Old 08-09-2019, 08:51:30 PM
Some of those old "field modifications" are interesting. I have generally repaired them but now looking back I wish I would have kept some of those unique ones on my engines. I looked a little closer at the picture and your Engine is definitely a battery igniter engine. It has the battery ignitor trip and a priming Cup on the side of the cylinder.
Old 08-16-2019, 11:28:47 AM
Default Re: Economy With Mill
I got the other engines and the other machine home, I have no clue what it was used for and neither did the guy who sold it to me. The FM H was also converted to spark plug and carburetor and the David Bradley is in pretty good shape. I think the H will be my winter project.
ID:	341555   Click image for larger version
ID:	341556   Click image for larger version
ID:	341557   Click image for larger version
John deere feed mill or hammer mill David A. Farm Antiques and Collectibles 1 02-11-2015 01:21:36 PM
economy and cider mill SteveK Hit & Miss Gas Engine Discussion 3 06-05-2014 06:05:56 AM
Unidentified Feed Mill, Grist Mill, Grinder Shawn Rogers Farm Antiques and Collectibles 7 09-02-2009 09:49:24 AM
Early Challenge Windmill & Feed Mill Co Mill Steve Barr Farm Antiques and Collectibles 6 08-16-2009 12:14:59 PM
Grain mill? (or cider mill) MarkL Farm Antiques and Collectibles 19 10-30-2008 10:11:10 PM
