Herculies 3hp video and need some help
this thread has 14 replies and has been viewed 1366 times
Old 10-12-2009, 11:14:42 PM
IronCity2006's Avatar
IronCity2006 IronCity2006 is offline
Location: Hoopeston, Illinois (90 miles south of Chicago)
Default Herculies 3hp video and need some help
http://www.youtube.com/watch?v=Ar1SeGq4nu4
Just got it running last night, bought it at portland in bad shape missing a few parts but otherwise a nice peice of iron. I belive it ran eather a cement mixer or some kind of crusher as it has a gear on the power side.
Since I dont have a mag (borrowed it off my other 2.5 economy) Does anyone have a spare ignitor and mag for this?
Something that is bugging me about it and I am not sure if its right the gov side of the piston is tapered by the flyballs and the flyballs are making contact with the piston. Anyone else had this problem? How did you fix it ? You can hear it in the video sounds like a wristpin but its not
Old 10-12-2009, 11:30:57 PM
Junkologist's Avatar
Default Re: Herculies 3hp video and need some help
If you lengthen the governor pin or somehow reduce the distance that the detent needs to travel to engage the catch block, then the governor balls won't fly out so far and come into contact with the piston. You may also be able to mesh the gears differently and time the governor so it doesn't hit the piston. I had a 3hp Jaeger that had the same bevel on the piston, but I didn't have the problem you have.
SmokStak member #146
Old 10-12-2009, 11:33:12 PM
Nate S's Avatar
Nate S Nate S is offline
Ive heard some people say you have to time the gov so it wont do that dont know if it works or not, I had trouble with my 3hp doing the samething, i put a long spring in the gov so it would hold the weights in farther but if its soft enough it wont make it run any faster.
The Following User Says Thank You to Nate S For This Post:
Old 10-13-2009, 12:26:02 AM
Christian Berlin's Avatar
Christian Berlin Christian Berlin is offline
you have to time the gov or else you loose the piston
The Following 2 Users Say Thank You to Christian Berlin For This Post:
Old 10-13-2009, 01:23:19 AM
Funny thing is I moved it so it wouldnt hit but it still hits. I will try again tommorow and post another video!!!
Old 10-13-2009, 06:36:06 AM
Walt Beeman's Avatar
Walt Beeman Walt Beeman is offline
Iron City,
Here is a link to Glenn Karch's Hercules Engine articles in GEM, there is a lot of good information to be found here, hope it helps.
http://www.herculesengines.com/hercu...newsindex.html
Keep Enjoying Old Iron,
Walt Beeman
The Following User Says Thank You to Walt Beeman For This Post:
Old 10-13-2009, 09:02:44 AM
Joe Morris Joe Morris is offline
This is one of a few H. P. sizes of Hercules engines with this problem. I have only seen one. and solved it by simply timeing the governor/flyball gear so that the flyballs were vertical when the piston is at bottom dead center. It works, and it was a little hard to find what all the noise and clatter was about while the engine was running. On most all Hercules engines I have ever seen there is no way that the skirt can hit the governor flyballs . Good luck in a good hobby,Joe Morris
The Following User Says Thank You to Joe Morris For This Post:
Old 10-13-2009, 12:43:18 PM
After much thinking, Does anyone rember a post from a man down in TN who lost the piston, con rod and gov on a 5hp economy? Could this have been what happened??????
I would really like to know
And to anyone with this size engine could I get a few pics? Something dont seem right on mine
Old 10-13-2009, 01:40:09 PM
MCanady's Avatar
MCanady MCanady is offline
My 2 1/2E Economy when running at it's fast setting the governor weights will strike the Cylinder. I only run it at the slow or mid setting so it has not been a problem for me. Merton
Old 10-13-2009, 02:26:07 PM
Ray Cardoza's Avatar
Ray Cardoza Ray Cardoza is offline
Could it be the wrong piston ? may be the original broke at some time and was replaced with the wrong one.
Old 10-13-2009, 03:01:34 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
I have had 2 1/2, 2 3/4 and 5 HP Hercules and Economy engines where the governor weights were striking the back of the cylinder. You may time the governor as mentioned before, but what you really need to do is make a longer governor shaft and weld in the back side of the arm that runs against the governor shaft. The combination of a worn shaft and wear point on the piece that the pin pushes against causes the problem you are experiencing.
Old 10-13-2009, 03:05:36 PM
Temple2426's Avatar
Temple2426 Temple2426 is offline
I would think that the gov weights are slinging to far out. Mabey if you replace the spring on the gov that will help.
Old 10-13-2009, 03:07:48 PM
Temple2426's Avatar
Take Joel Mosleys advice! That guy knows his hercules and economy stuff.
Old 10-13-2009, 03:17:58 PM
Thanks for the vote of confidence Matthew. Just to clear up the spring comment. The spring will not limit the amount the weights fly out. Only at what speed they fly out. The governor weights will only fly out as far as the detent blade will allow them to plus a little extra for wear and tear on all of the pins and flex of the detent blade. Just grab the governor weights and pull them out until the detent makes contact with the push rod and you will see what I mean. The longer the governor pin is, the closer the detent is to the push rod. This limits the governor weight travel so they won't open up as far and hit the cylinder or the piston. You do want a soft spring if you are going to slow the engine down.
The Following User Says Thank You to Joel Mosley For This Post:
Old 10-13-2009, 09:58:28 PM
Chris J's Avatar
Chris J Chris J is offline
It did the same thing on our 2 1/2 H.P. Economy, it is a real simple fix, your flyball govornors are 180 off if they are hitting the piston, all you have to do is turn it the 180, and then it is fixed, the govornor is not timmed, so it does not change anything if you turn it the 180.
It did take us a little while of looking to see what the problem was, but atleast it was a very easy fix.
The Following User Says Thank You to Chris J For This Post:
I quite like this (video) Dan Dyman Steam Stationary Engines, Traction Engines 21 08-12-2009 06:50:06 PM
1942 Herculies ZXB 4 cylinder engine helmben Hit & Miss Gas Engine Discussion 2 07-16-2009 11:53:29 PM
New Way Video Fred Van Hook Hit & Miss Gas Engine Discussion 1 02-07-2009 10:16:01 AM
new New Way video Jim Sherman Hit & Miss Gas Engine Discussion 0 12-02-2007 08:19:41 PM
Video? Jebaroni Hit & Miss Gas Engine Discussion 12 01-10-2005 07:42:31 AM
