Witte Restoration - 1912 8 HP Headless
this thread has 31 replies and has been viewed 3637 times
Old 02-12-2012, 05:06:13 PM
MSimons's Avatar
MSimons MSimons is offline
Default Witte Restoration - 1912 8 HP Headless
I thought I would create a thread detailing the mechanical restoration my dad and I are in the progress of. The engine is a fairly early (1912) 8 HP headless Witte. The engine came out of central North Dakota and was used to run the leg of a small grain elevator.
Being an early engine, it has several different features than the later 8 HP engines.
1. The water hoper is about the physical size of a later 6 HP engine.
2. The stroke is only 8" which is the stroke of a later 6 HP engine.
3. The exhaust port is 1.5" which is the size of a later 4 HP engine.
4. The carburator/mixer is the early snorkle style that is threaded into the valve cage instead of bolted on.
5. The bore (6.5") and flywheel diameter (36") is the same size of a later 8 HP engine.
ID:	128604   Click image for larger version
ID:	128605   Click image for larger version
ID:	128606   Click image for larger version
The Following 9 Users Say Thank You to MSimons For This Post:
Old 02-12-2012, 05:10:22 PM
MSimons's Avatar
Default Re: Witte Restoration - 1912 8 HP Headless
Fortunately the original battery box was still with the engine. After a little work I was able to get it looking pretty good.
ID:	128608   Click image for larger version
ID:	128609   Click image for larger version
Name:	002 - Copy.jpg
The Following 5 Users Say Thank You to MSimons For This Post:
Old 02-12-2012, 05:24:23 PM
MSimons's Avatar
The main and rod bearings were in bad shape. The babbitt mains were loose in the block. The bearings had been tightened up many times as there were no more shims left. Getting the gibb keys out not the easiest as the last time they were installed they had been coated in white lead. In addition, they were driven so far in, that they were cutting into the main bearings.
ID:	128611   Click image for larger version
ID:	128612   Click image for larger version
The Following 3 Users Say Thank You to MSimons For This Post:
Old 02-12-2012, 05:28:39 PM
MSimons's Avatar
The crank needed to be reground as the round bearing surface was in very bad shape. The mains were alright but since we had the crank in the grinder we ground the whole thing.
ID:	128614   Click image for larger version
ID:	128615   Click image for larger version
ID:	128616   Click image for larger version
Name:	058 - Copy.jpg
Old 02-12-2012, 05:31:04 PM
MSimons's Avatar
Just for fun, I took the following picture. This shows the size difference of the 8 HP crank versus a 30 HP headless Witte crank.
Old 02-12-2012, 05:38:10 PM
MSimons's Avatar
Next, the camshaft gear and shaft had to be fixed so that they could be used to set the height of the crankshaft when the new bearings were poured.
We honed out the cam/cam gear in the pin fitting machine Which I have included some pictures of. This is the handiest machine but you need a lot of arbors to make use of it.
I also included a close-up of an old tooth repair on the cam gear.
Name:	007 - Copy.jpg
ID:	128619   Click image for larger version
Name:	013 - Copy.jpg
ID:	128620   Click image for larger version
ID:	128621   Click image for larger version
Name:	004 - Copy.jpg
The Following 2 Users Say Thank You to MSimons For This Post:
Old 02-12-2012, 05:45:35 PM
MSimons's Avatar
Here is the new shaft for the cam gear.
ID:	128623   Click image for larger version
The Following User Says Thank You to MSimons For This Post:
Old 02-12-2012, 05:51:18 PM
MSimons's Avatar
Here shows the setup we used to pour the bottom half of the mains.
They turned out fair considering we poured them to size versus pouring them undersize and boring them to size.
Name:	062 - Copy.JPG
ID:	128626   Click image for larger version
Name:	061 - Copy.JPG
ID:	128627   Click image for larger version
Name:	069 - Copy.jpg
ID:	128628   Click image for larger version
Name:	066 - Copy.JPG
Old 02-12-2012, 05:53:21 PM
MSimons's Avatar
Then we poured to top halfs.
ID:	128630   Click image for larger version
Old 02-12-2012, 05:56:18 PM
MSimons's Avatar
We decided to make a reusable jig to pour the rods as we plan on doing a lot more of this type of work.
Name:	008 - Copy.JPG
ID:	128632   Click image for larger version
Name:	010 - Copy.JPG
ID:	128634   Click image for larger version
Name:	011 - Copy.JPG
ID:	128635   Click image for larger version
Old 02-12-2012, 06:01:20 PM
MSimons's Avatar
The rod had a crack on the wrist pin end as someone had over-tightened it trying to tighten the wrist pin bushing which was completely worn out. We decided to braze it up and put in a solid bushing instead of a split one to give it a little more strength.
ID:	128638   Click image for larger version
ID:	128640   Click image for larger version
ID:	128641   Click image for larger version
Old 02-12-2012, 06:07:29 PM
MSimons's Avatar
Next we made new rode bearing shims. Not a very exciting part of the restoration, but I thought I would share a few pictures of the jig we use to punch the holes in the press.
ID:	128643   Click image for larger version
ID:	128644   Click image for larger version
ID:	128645   Click image for larger version
Old 02-12-2012, 06:10:14 PM
MSimons's Avatar
Lastly we made new rod bolts and machined the rob bearing in the milling machine.
ID:	128647   Click image for larger version
ID:	128648   Click image for larger version
ID:	128649   Click image for larger version
Old 02-12-2012, 06:19:35 PM
MSimons's Avatar
Next we remachined the piston ring groves. For this project we were able to buy off the shelf rings (2 per groove) and then used one ring spacer to account for what was removed by truing up the ring grooves.
We then honed the block a little. The bore was in pretty good shape except for a small groove where the wrist pin had come loose at one time. The groove was pretty small so we weren't too concerned about it. If it turns out there is any blow by because of this samll groove, we will take the cylinder off and bore and sleeve it.
ID:	128652   Click image for larger version
Old 02-12-2012, 06:35:55 PM
MSimons's Avatar
Next a new oversized wrist pin was made and the walking beam was rebuilt. The cam roller was in bad shape. The oil hole was plugged solid so the pin was badly worn. In addition the roller had a very large flat spot.
ID:	128655   Click image for larger version
ID:	128656   Click image for larger version
Name:	022 - Copy.JPG
ID:	128657   Click image for larger version
Name:	020 - Copy.JPG
Old 02-12-2012, 06:37:57 PM
MSimons's Avatar
A few more pictures of the walking beam.
Name:	026 - Copy.JPG
ID:	128659   Click image for larger version
Name:	027 - Copy.JPG
Old 02-12-2012, 06:47:14 PM
MSimons's Avatar
The next thing to tackle was the valve cage. It needed a fairly large crack repaired. I decided to peg it versus welding because I wanted to preserve what paint remained and the original pitina. This would have all been lost though the preheating process required to weld it.
We used the Stick-N-Lock system versus tappered pegs as tappered pegs would have just pushed the material out versus pulling it together. If you haven't heard of Stick-N-Lock it is a very clever system that uses a special thread that doesn't have a traditional thread that pushed the material apart when tightened. It has a back angle on the thread that will pull the material together. It is a pretty expensive repair versus traditional pegs but it is very strong.
ID:	128661   Click image for larger version
ID:	128662   Click image for larger version
Name:	015 - Copy.JPG
ID:	128663   Click image for larger version
Name:	017 - Copy.JPG
Old 02-12-2012, 06:50:40 PM
MSimons's Avatar
All was going well until I broke off the expensive tap in the very last hole. We have used the tap on several projects and I could tell it was getting dull. I should have got out the new tap - I guess that is a leason learned.
Name:	018 - Copy.JPG
ID:	128665   Click image for larger version
Name:	028 - Copy.JPG
ID:	128666   Click image for larger version
Name:	031 - Copy.JPG
ID:	128667   Click image for larger version
Old 02-12-2012, 06:54:30 PM
MSimons's Avatar
This is the almost finished product. I ground off the pegs with a die grinder and then did a little blending work with a porting stone. The stone leaves a little roughness and removed all the grinding marks. Unfortunately I don't have a closeup picture of the actual finished product.
Name:	034 - Copy.JPG
Old 02-12-2012, 06:59:49 PM
MSimons's Avatar
Next was the seat and guide work. On the exhaust, I simply bored out the guide and put in an oversized stem. We didn't do the same on the intake as we wanted to keep the valve the same weight so that we didn't have to monkey around finding the right spring tension since the intake doesn't have a rocker arm. Therefore we put in a guide liner.
ID:	128670   Click image for larger version
ID:	128671   Click image for larger version
ID:	128672   Click image for larger version
My new Witte 6hp Headless Chris Steffen Hit & Miss Gas Engine Discussion 9 05-19-2010 10:13:10 PM
3hp headless witte JohnCCarlson Magnetos, Ignition Coils and Spark Plugs 2 06-01-2009 07:48:52 PM
Headless Witte RPM Brent Snyder Antique Engine Archives 1 11-02-2004 05:45:24 PM
6HP Headless Witte Mike Castner Antique Engine Archives 6 07-23-2002 04:15:34 PM
3 hp Witte headless Al Hettich Antique Engine Archives 2 07-01-2002 12:48:22 AM
