Witte Restoration - 1912 8 HP Headless
this thread has 31 replies and has been viewed 3629 times
Old 02-12-2012, 07:02:46 PM
MSimons's Avatar
MSimons MSimons is offline
Default Re: Witte Restoration - 1912 8 HP Headless
The guide liner what then honed to size in the pin fitting machine. Then the seats were ground.
ID:	128674   Click image for larger version
Name:	053 - Copy.jpg
ID:	128675   Click image for larger version
ID:	128676   Click image for larger version
Name:	054 - Copy.JPG
The Following 2 Users Say Thank You to MSimons For This Post:
Old 02-12-2012, 07:06:02 PM
MSimons's Avatar
Here is a picture of the new exhaust valve that was made. The tip of the valve was cut back down to the original size in order to use the orginal valve keeper parts.
I forgot to mention earlier that the surface of the valve cage that bolts to the block was resurfaced as well.
Name:	055 - Copy.JPG
ID:	128677   Click image for larger version
Name:	056 - Copy.JPG
The Following User Says Thank You to MSimons For This Post:
  #23
Old 02-12-2012, 07:12:43 PM
MSimons's Avatar
Now are some pictures of the assembly. The rod and crank ligned up nicely so that gave us some assurance we poured the bearing in the right spot
We made new larger gib keys so they would stick out a little further than the old ones and not get into the bearings.
Name:	030 - Copy.JPG
ID:	128680   Click image for larger version
Name:	029 - Copy.JPG
ID:	128681   Click image for larger version
Name:	036 - Copy.JPG
ID:	128682   Click image for larger version
Name:	060 - Copy.JPG
  #24
Old 02-12-2012, 07:16:27 PM
MSimons's Avatar
The governor weights and brackets weren't hardly worn so I simply made new pins out of drill rod.
Name:	057 - Copy.JPG
ID:	128684   Click image for larger version
Name:	059 - Copy.JPG
ID:	128685   Click image for larger version
  #25
Old 02-12-2012, 07:24:36 PM
MSimons's Avatar
Although not everything is done, we were at a point where we were able to start the engine for the first time. It ran well considering we didn't have the gas tank hooked up and were pouring gas in with a priming can. There was no blow by and it had very good compression.
There are still about a half a dozen things to finish and then I will take a video of the running product.
Old 02-12-2012, 08:34:53 PM
That's a nice looking engine. I had a 6 hp headless in the 9000 serial number range and it was the physical size of a later 4 hp.
  #27
Old 02-12-2012, 09:21:18 PM
Craig M. Strader Sr. Craig M. Strader Sr. is offline
Very good info in your restoration project and thanks very much for sharing.
Craig
The Following User Says Thank You to Craig M. Strader Sr. For This Post:
  #28
Old 02-12-2012, 11:40:49 PM
Alan Svanes Alan Svanes is offline
Thanks for posting all of the pictures.
Alan
The Following User Says Thank You to Alan Svanes For This Post:
  #29
Old 02-19-2012, 09:49:20 PM
MSimons's Avatar
Got some time to work on the Witte some more this weekend.
- Fixed most of the leaks in the gas tank.
- Replaced some of the fuel piping that was in poor shape.
- We discovered that when the intake valve cage is screwed in it distorts the valve seat just enough that it won't seal perfectly so we lapped in the valve and it seats great now.
- Got the pulley put on
- Wired the ignition.
- Few other misc things that I can't remember right now
Lastly we decided to make a new offset shaft for the camshaft gear. We discovered that the cam gear was binding in a few places and was just too tight. The first offset wasn't enough so we ended up making another shaft. I told my wife I needed to buy another engine so that I had a use for the extra parts. She didn't laugh at my joke.
ID:	129269   Click image for larger version
ID:	129270   Click image for larger version
Old 02-19-2012, 09:56:56 PM
MSimons's Avatar
And here is a video of the engine. I would like to find a little weaker governor springs to slow it down just a little. Right now it is running at 200 RPM before it will fire.
It is always nice to finish a project and get started on the next one. I think the next on is going to be a lot more work however...
The Following 10 Users Say Thank You to MSimons For This Post:
  #31
Old 09-17-2019, 03:46:14 PM
Johnhenry1996 Johnhenry1996 is offline
Hello,
Great job on the restoration and the photos. I just bought a non-running 1912 Witte 8 HP and I am going to be doing the same thing. I dont have all the metal working tools though. I may be reaching out to you for advice if you don't mind. Thank you.
Old 09-18-2019, 01:35:37 AM
Skip Landis Skip Landis is offline
Mike, i don't know why you didn't charge those original batterys & use them. Nice visiting with you at Rolag. skip
My new Witte 6hp Headless Chris Steffen Hit & Miss Gas Engine Discussion 9 05-19-2010 10:13:10 PM
3hp headless witte JohnCCarlson Magnetos, Ignition Coils and Spark Plugs 2 06-01-2009 07:48:52 PM
Headless Witte RPM Brent Snyder Antique Engine Archives 1 11-02-2004 05:45:24 PM
6HP Headless Witte Mike Castner Antique Engine Archives 6 07-23-2002 04:15:34 PM
3 hp Witte headless Al Hettich Antique Engine Archives 2 07-01-2002 12:48:22 AM
