10 20 Titan bearings
this thread has 10 replies and has been viewed 2644 times
Old 03-06-2012, 11:54:41 PM
Warren Wolf Warren Wolf is offline
Default 10 20 Titan bearings
Hi I am sure this has probably been discussed before but I couldn't find anything.
Does anyone know where I can get replacement roller bearings for the front and rear wheels for a 10-20 Titan? It is a 1920.
Old 03-07-2012, 09:12:41 AM
Default Re: 10 20 Titan bearings
Hi ,I wasn't aware they had roller bearings in the rear wheels. I think mine (1921) has plain bearings. Try Kaman Industrial Technologies in Nj for the front rollers. You may have to ask for them by sizes not part no.s Rob
The Following User Says Thank You to Rob Charles For This Post:
Old 03-07-2012, 11:59:18 AM
Yep. the book that I have shows them as roller bearings.
Thanks for the lead, I appreciate it.
Warren
Old 03-08-2012, 12:17:58 AM
Nebraska Kirk Nebraska Kirk is offline
I put a PTO extension on a Farmall Regular that I rebuilt. The straight roller bearing that supports the end of the extension had several of the rollers badly damaged by rust. I made new rollers out of precision ground hardened steel shaft and installed them in the original roller cage. Worked out just great! The hardened shaft only cost $15. Maybe you can do this with your bearings??
Old 03-08-2012, 07:30:42 AM
Marcel P's Avatar
Marcel P Marcel P is offline
I doubt whether you can still find those but if you can save the cages you can make new ones yourself. Depending on the hub bore it may need re-boring as well. You can compensate with thicker rollers. I posted pictures in on or another thread but can't find them right now.
Marcel
Old 03-08-2012, 02:52:25 PM
I would bush them with bronze.
You could use a steel sleeve and bush that to save on the cost of bronze.
I don't believe any Hart Parr tractor ever built had anything but bushed wheel hubs all around.
Old 03-08-2012, 03:10:11 PM
Roger Byrne's Avatar
Roger Byrne Roger Byrne is offline
Like Craig said . . . been there and done that . . . the bronze worked great and no problems. One of the Titans I did with bronze, was restored over 30 years ago and is still going strong. I have made new rollers for a different Titan, but for all the work to machine the axle, boring of the hub and then machine new over-sized rollers for the bearing cages, if it were mine and it had a lot of wear, I'd go the bronze bushing route.
Preserving Mechanical History for Future Generations since 1965
The Following 2 Users Say Thank You to Roger Byrne For This Post:
Old 03-08-2012, 05:11:17 PM
I would try to see if they are available. If they are standard size there might be something out there. I got a new ball bearing unit for the 1918 GS&M Beaver tractor, friction drive shaft from a good local bearing supply!
RM
Old 03-08-2012, 05:49:32 PM
Joe Prindle's Avatar
Joe Prindle Joe Prindle is offline
Berliss Bearing makes some sizes of the old style pencil bearings, you can register and download the catalog at www.berliss.com . Motion Industries is a distributor.
With that said, I am going to replace the pencil bearings in my Titan wheels with bronze bushings. The late titans had bushings instead of bearings and they held up just fine.
The Following 3 Users Say Thank You to Joe Prindle For This Post:
Old 03-08-2012, 08:32:37 PM
texasbest texasbest is offline
I went the long route on my 18/32 Case. I found new outside cages. The axle itself was worn too bad & we finally had to make a new one. The rollers I ended up having made out of std shafting & heat treated. We talked about bushing but my shaft was too worn.
Roby Whitehead
Old 03-12-2012, 03:21:12 PM
rory woolf rory woolf is offline
I bushed my Titan with bronze, it worked well over ten years.
I was wondering what your opinion of using nylon would be?
Rory.
When is a Titan not a Titan, but a "TITAN " TRACTOR? Paul Spence Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 24 03-05-2016 11:34:05 AM
bearings Kyle McGee Hit & Miss Gas Engine Discussion 2 04-01-2006 07:34:53 PM
bearings BDMelon Hit & Miss Gas Engine Discussion 12 10-09-2005 10:19:58 AM
IHC 10 HP M bearings Dave Gardiner Antique Engine Archives 3 05-03-2004 08:02:44 PM
JD-E 1-1/2 Bearings Jim Tremble Antique Engine Archives 3 10-27-2003 11:16:21 AM
