Onan 2.8 KV need a schematic for an Onan KV Votage regulator
this thread has 7 replies and has been viewed 2713 times
Old 08-27-2012, 10:51:55 AM
uncle Ray uncle Ray is offline
Default Onan 2.8 KV need a schematic for an Onan KV Votage regulator
I need a schematic for an Onan KV Votage regulator
Not just the pin-out of the unit, the parts schematic of what is on the inside..
any help would be appreciated
Thanks, Ray
Old 08-27-2012, 02:23:04 PM
len k len k is offline
Default Re: Onan 2.8 KV need a schematic for an Onan KV Votage regulator
I think that would be hard to find. Some people here have done the legwork and traced out schamatics for AC reg's in other generators like NHM, NHD.... . I suspect they didn't vary too much ,yours maybe similar see thread ----> http://www.smokstak.com/forum/showth...t=99743&page=6 (arround post #113, pics @ 61, 53, .... ) I would check the IGBT ( power output transistor) on the heat sink, 1/4 inch thick Aluminum plate)
Alternatively Flight Systems sells good cheap replacement regulators.
Old 08-27-2012, 02:53:02 PM
Billy J Shafer's Avatar
Onan didn't publish that information. Sealed so no field repairs can be done.
Old 08-27-2012, 08:50:29 PM
I was looking to build my own design.. My control board works better and it is all SMD..the prices they charge are ...well you know
Old 08-27-2012, 09:39:59 PM
Good luck !!
Unless you have some electronics background (like a EE) it would be hard to come up with your own good design, (unless you copy it off the interenet.) Prototypes always have a bug or two. And the time you would spend testing and getting the bugs out.....it would only make sense if your time was worth " 2 cents per hour" or you were going to manufacter and sell ~1000 to 10,000+ units/yr. I have done the latter at several big companies.
Nothing magical about SMD, just smaller and cheaper to produce in large quantities. And more thermal problems in the engineering design stage.
For 1 or 2 unit quanties it's cheaper to repair or buy a new unit. Talk to Flight Systems they are a good group of techs. They are cheaper than Onan, and I think they have a better regulator. I've talked engineering with them, they are competant.
Alternatively you could buy an aftermarket feild exciter AC regulator. It takes 110 VAC and supplies field drive. I think Powertronics makes some??
Old 08-28-2012, 07:44:45 AM
Talking Re: Onan 2.8 KV need a schematic for an Onan KV Votage regulator
40 years as an EE
you are driving some of the things I have worked on
Old 08-28-2012, 07:59:54 AM
MBB MBB is offline
Not to get off subject but hows that storm impacting you? Your much further inland but its a wide storm.
Old 08-28-2012, 01:30:36 PM
Uncle Ray....Sounds like you will be able to do it.
In some previous models of Onan like the Emerald and early Marquis models, they had 2 circuit boards. One was the AC voltage regulator (no factory published schematics) and 2nd the control broard whose schematics were published, basically relay logic. For schematic see end of manual at ----> http://www.cumminsonan.com/www/pdf/m.../965-0531B.pdf.
I think in your model they combined both into one board and potted the whole thing. A pain to work on, but not impossable for you. The potting on my old regulator is clear and pulls apart without too much trouble.
A design feature you should think about is how you want the regulator to respond when a overload slows the engine. The Hz will drop. These Rv type Onan's with electronic regulators reduce the AC output voltage as Hz drop. This is for transformer and inductor load "jwL" impedence issues, to avoid higher currents and help reduce the load on the engine.
An issue on aftermarket regulators that I noticed is they have a stability adjustment pot to customize the reg for different gensets.
While you are at it, if you want to use the gen to power your house, a feature you may want to include is to not bond the "current carrying neutral" and the "safty ground" in the regulator. Gives you flexability in meeting NEC code. I am modifying my potted regulator to remove this internal bond for just this reason.
Best of luck, I think you can do it.
Onan 3.0 DJA Need schematic MELumpkin Onan Generators 8 02-05-2012 10:18:13 PM
Onan 7.5 Model DKD Low votage output joebus Onan Generators 4 09-06-2011 11:01:31 PM
Onan Schematic hlflorek Onan Generators 0 11-01-2010 12:12:46 PM
Schematic for YD Regulator Board needed Don Smith Onan Generators 12 05-30-2009 07:24:18 AM
MEP-003 Battery Rectifier Regulator Schematic JimThescot989 Military MEP and Aircraft Gen-Sets 1 12-29-2008 02:45:34 PM
