Wisconsin Engines
Exhaust valve rotator on AEND?
this thread has 3 replies and has been viewed 1438 times
Old 01-01-2013, 06:54:09 AM
Jim M. Jim M. is offline
Default Exhaust valve rotator on AEND?
Gentlemen, My AEND has an exhaust valve rotator and a shorter exhaust valve spring. My shop manual doesn't show a rotator on this model. It has a bent stem on it's exhaust valve I believe from using the wrong tool to remove it as the spring is nicked up also. I will replace the Stellite exhaust valve but should I use the rotator or replace it with a standard spring and seat? Did the AEND ever come with a rotator? Thanks and have a happy New Year! Jim
Old 01-01-2013, 03:50:33 PM
Kelley Hulsey Kelley Hulsey is offline
Default Re: Exhaust valve rotator on AEND?
Ihave a 1958 AEND w/ a rotator also.
The Following User Says Thank You to Kelley Hulsey For This Post:
Old 01-01-2013, 06:43:50 PM
Phil P Phil P is offline
Hi
The Stellite valve requires the valve rotor. The AEND indicates this valve came installed from the factory and that would include the rotor.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 01-01-2013, 07:30:15 PM
Thanks guys, Since I didn't see it in my AEN-AENS manual I thought it might be a field upgrade. Jim
1-1/2 HP IHC M Exhaust Valve John Cunningham Hit & Miss Gas Engine Discussion 6 07-14-2009 06:38:10 AM
Exhaust valve setting flasks Hit & Miss Gas Engine Discussion 3 02-26-2008 02:25:12 PM
Exhaust Valve hit by Piston Atique Generators & Electric Motors General Discussion 8 10-12-2004 10:58:49 AM
Exhaust valve springs Eric McKenna Antique Engine Archives 1 07-12-2003 08:05:24 PM
stuck exhaust valve Eric McKenna Antique Engine Archives 5 09-02-2002 05:35:41 PM
