bosch starter/generator
this thread has 1 replies and has been viewed 4592 times
Old 03-08-2004, 09:26:17 PM
chuck ore
Default bosch starter/generator
Tring to get a Albin Marine engine to start the Bosch start/generator turns over really well,but you can stop it with your hand ( no power)It certainly won't start the engine it won't even roll the belt.Any ideas where to look for the problem? Thanks Chuck K.
Old 03-09-2004, 11:06:49 AM
edurand
Default Re: bosch starter/generator
Chuck:
If the Bosch starter/generator is anything like the old Delco units (teens Buick, etc.), they "motor" with very little power when the ignition is first turned on because the hookup is for generating. The front end of the starter/generator shaft was connected to a one way clutch that, in turn was connected to the timing gear train, letting the unit turn freely when "motoring".
When the starter pedal was pushed in; first, the starter gear was engaged (stalling the "motoring" generator). At the end of the pedal push, a ramp on the shaft lowered a big brush to the commutator that energized a heavy field winding and made the generator into a high torque motor for cranking.
When the pedal was released, the motor was turned back into a generator and the gear was disengaged, the generator now being turned through the one-way clutch from the timing gear train.
Then, there was the Dodge "Silent Starter", which was driven all the time from the timing chain. It both cranked and generated without the one-way clutch and operated kinda like the Delco unit.
Now, can I go back to sleep?
Take care - Elden
Elden's Junky Web Page
Caterpillar 22 - Bosch RJF generator Puffie40 Antique Farm Tractors 1 07-23-2019 06:31:30 PM
Bosch generator with sachs two stroke timbo917 Small Air Cooled Gasoline Engines 18 01-18-2019 01:56:30 PM
Ford Generator? generator-starter? TekNik The Junque Drawer 5 04-09-2014 09:10:01 PM
Bosch Generator stevengine The Junque Drawer 1 12-12-2012 09:40:58 PM
Vintage Robert Bosch Type K 50/6 - 500 generator SPutman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 03-25-2012 08:34:33 PM
