10 20 Deering
this thread has 5 replies and has been viewed 1606 times
Old 07-15-2013, 10:06:07 AM
Edgar Edgar is offline
Default 10 20 Deering
hey yall been playing around with my old 10-20 and man does the rear end sound loud and noisy!!I have plenty of fluid in it and ive had it taken all apart at one time or the other.so my question is----does every ones elses make a whinning noise in the rear end when driving???????????I have a f-20 that makes a little noise but not like the old 10-20?????thanks.edgar in west tn
Old 07-16-2013, 07:09:43 AM
Nebraska Cowman's Avatar
Nebraska Cowman Nebraska Cowman is offline
Default Re: 10 20 deering
yeah, the gears get worn they can be noisy. Also they are a lot louder with water for lubrication and not heavy oil. Have you pulled the drain plug and let the water out? Water is heavier than oil and will be on the bottom.
The Following User Says Thank You to Nebraska Cowman For This Post:
Old 07-16-2013, 08:34:21 AM
hey thanks for your response.i have had the complete tractor taken apart at one time and went thru everthing that looked like needing replaced or fixed.it has fresh oil in it and it reminds me the way my F-20 sounds only louder?????I will never wear it out farming with it !!!!!!!!!!just for playing around on.i was told this am that fordsons were the worst about rear end noise???????
Old 07-16-2013, 09:31:42 AM
K Cooke K Cooke is offline
The worst for whining is the W40 gassers
The Following User Says Thank You to K Cooke For This Post:
Old 07-16-2013, 09:59:18 AM
GreasyJohn GreasyJohn is offline
My old fordson N used to howl but I loved that noise my MH 55 and 44 are quite loud also but they had a very hard life
The Following User Says Thank You to GreasyJohn For This Post:
Old 07-16-2013, 10:17:53 AM
Russ Hamm's Avatar
Originally Posted by K Cooke View Post
The worst for whinning is the W40 gassers
That's or sure, mine makes you want to wear ear protection. McCormicks seem to be pretty famous for gear noise, but most often because of wear from longevity of service.
McCormick Deering 22-36 & 10-20 Nebraska Kirk Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 12-19-2011 11:45:51 PM
McCormick-Deering 10 HP M Tim Smith Hit & Miss Gas Engine Discussion 13 12-11-2011 10:14:20 AM
McCormick Deering T-20 Joe Hugh Antique Farm Tractors 64 11-08-2009 10:45:00 PM
1 1/2 HP Mc Deering rod brg. Chuck Rich Antique Engine Archives 2 05-19-2003 08:43:20 PM
3hp M Deering. John Hammink Antique Engine Archives 0 05-13-2002 05:17:32 PM
