Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Kohler Generators
Kohler Generators
Kohler 3.5RM62 Spec. 620 H.3.4.5.7 with kohler A-23858 information
this thread has 2 replies and has been viewed 2156 times
Old 08-12-2013, 12:53:24 PM
bobfish1 bobfish1 is offline
Default Kohler 3.5RM62 Spec. 620 H.3.4.5.7 with kohler A-23858 information
I just bought 5 of these generators which were Civil Defense backup with them being designed to sit on a pad outdoors and fed from liquid propane but it has the fuel pump to. Does anyone have info on the generator or controller I will try to post some pictures when I can.
---------- Post added at 11:53 AM ---------- Previous post was at 11:46 AM ----------
Other info is it is a 3.5 KW 115/230 V and 12 volt battery with a water cooled kohler engine possibly the L600. Since they are made to withstand the elements there is a panel on the end with hour gauges, fequency and volts on a couple of them. A couple must have had the voltage or frequency gauges removed. Also they range from 800 hours to 1200 hours on the hour meter. Didn't think that was to bad for 60 year old machines which look like 4 of them could be started right away with just fuel and battery.
Old 08-12-2013, 11:10:19 PM
LWB250 LWB250 is offline
Default Re: Kohler 3.5RM62 Spec. 620 H.3.4.5.7 with kohler A-23858 information
You're missing a digit for the controller number. Should be a letter followed by a six digit number.
Dan
Old 08-13-2013, 10:21:18 AM
Sorry about that the Kohler Controller No. is A-243858
---------- Post added at 09:21 AM ---------- Previous post was at 09:18 AM ----------
I also looked under the cover for the wiring diagram but it was gone. Maybe one of the others has it and I will check. Just inquiring about things and Thanks for any help someone can provide.
Kohler 30rz282 spec 185062-82l ser 300834 need engine information SunsetServices Kohler Generators 5 06-29-2013 10:04:16 PM
Kohler Model 2.5RM62 Vanman Kohler Generators 2 05-03-2013 02:32:57 PM
Kohler K331 / 3.5RM62 Shock Kohler Generators 2 11-03-2012 08:52:53 AM
Kohler 5RM62 failed generator ten-mile Kohler Generators 6 05-01-2010 12:50:36 PM
Kohler 5RM62 Sad story, need a few parts ten-mile Kohler Generators 2 04-19-2007 09:28:46 AM
