Steam Engines
Platform Construction
this thread has 4 replies and has been viewed 1680 times
Old 11-17-2013, 03:21:38 PM
Beth V's Avatar
Beth V Beth V is offline
Default Platform Construction
Every company has their idea of the ideal platform, here is Port Huron's:
How about others?
The Following User Says Thank You to Beth V For This Post:
Old 11-18-2013, 03:16:40 PM
Default Re: Platform Construction
How well does the brake work?
Jeff
Old 11-18-2013, 03:29:12 PM
Beth V's Avatar
It will slow down............if forgotten, and you try to move, it will stop on center......
The Following 2 Users Say Thank You to Beth V For This Post:
Old 11-18-2013, 04:30:23 PM
tannerbrethorst tannerbrethorst is offline
It would appear that Cabin Fever seems to be setting in on the 'Stak.
Old 04-15-2014, 09:43:41 PM
AndyG's Avatar
AndyG AndyG is offline
Keck Gonnerman had a substantial platform on their side-geared engine. I was told that the bracket on the boiler is designed to prevent it folding up in the event of a bridge collapse. The 6" channel iron frame is also much more than is needed to support the operator and water tanks.
ID:	193121   Click image for larger version
The Following 6 Users Say Thank You to AndyG For This Post:
Perfect Example of Why Someone Should ALWAYS be on the Platform Beth V Steam Stationary Engines, Traction Engines 75 09-22-2017 12:49:43 PM
18-32 Case Platform Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 12-18-2012 05:29:49 PM
Portable Platform Scale Charlie186 Farm Antiques and Collectibles 0 07-13-2012 03:26:13 PM
Howe platform scale granpa49 Farm Antiques and Collectibles 0 06-13-2011 09:45:56 PM
Hart-Parr-Platform d.j.baisch Antique Engine Archives 1 11-17-2002 09:45:34 PM
