10-20 McCormick Numbers
this thread has 5 replies and has been viewed 1186 times
Old 12-09-2013, 05:37:28 PM
RustyRelics UK's Avatar
RustyRelics UK RustyRelics UK is offline
Question 10-20 McCormick Numbers
Hello all,
Would I be correct in saying the engine Number on a 10-20 is the serial No ? my tag is missing from the dash and from what I have been told my tractor is a 1928 ... No oil filter, exhaust through the dash etc. I have a new tag for the dash but I would like to know if the engine No. (below the head on the right hand side by the governor) is the serial No. before I stamp it up ???
By the way after reading previous topics here on the stak, I rubbed some of my tractors over with Owatrol ... I couldn't believe how good the weathered old 10-20 came out ! So good the W30 got the same treatment
Thanks,
Carl Hargreaves
Name:	10-20 DEERING.jpg
ID:	181575   Click image for larger version
ID:	181576   Click image for larger version
Old 12-09-2013, 05:46:47 PM
Ken Majeski's Avatar
Default Re: 10-20 McCormick Numbers
On any that I ever had the tag number matched the engine number.
Unless you have a tractor that somebody changed parts on.
I'm not totaly sure about the long louvered hood on a 28 tractor though ? No doubt somebody else will come on that can tell you for sure.
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
Old 12-09-2013, 06:04:26 PM
Russ Hamm's Avatar
Yes, the long louvers are correct on 28 with the exhaust through the gas tank support.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
Old 12-09-2013, 06:34:43 PM
oldhammerhead oldhammerhead is offline
Hi Carl My 1928 tag # is the same as # on engine block Left side between lower rad outlet and intake manifold raised boss on engine with serial # stamped into it hope this helps.
The Following User Says Thank You to oldhammerhead For This Post:
Old 12-09-2013, 11:11:43 PM
Old-F20 Old-F20 is offline
The chassis tub should have a casting date on the bottom of it if you wanted to double check. its to the rear of the front axle stay rod mount.
this would give you an idea if the engine might have ever been changed out
The Following User Says Thank You to Old-F20 For This Post:
Old 12-10-2013, 09:50:26 AM
Thanks for all the information, I went and had a look at my 10-20 during my lunch break today, the eng # KC 106555 and the # under the transmission housing is 5-4-28
Thanks,
Carl Hargreaves
Deere and McCormick thresher serial numbers by year zubiedoobydoo Antique Farm Tractors 5 08-06-2016 07:41:48 AM
Converting Old Onan part numbers to New part numbers? Motorhead Onan Generators 4 11-27-2013 07:17:32 PM
LB McCormick Deering serial numbers Kevin in Utah Hit & Miss Gas Engine Discussion 2 06-22-2013 05:32:08 PM
McCormick Deering serial numbers. Russ Hamm Antique Farm Tractors 6 11-20-2009 12:08:47 AM
HSB numbers Buster Steam Stationary Engines, Traction Engines 6 02-11-2002 05:04:13 PM
