10-20 McCormick Help Needed
this thread has 2 replies and has been viewed 1291 times
Old 12-10-2013, 01:09:02 AM
Ironman Ironman is offline
Default 10-20 McCormick Help Needed
Does anyone here happen to know current, modern day part numbers for bearings and races for a McCormick Deering 10-20 front end? I'm not looking for original Deering part numbers. I'd like part numbers for Timken, SKF, or other brands that I can get from current distributors.
Old 12-10-2013, 03:03:55 AM
Fifty7ChevyNut Fifty7ChevyNut is offline
Default Re: 10-20 McCormick Help Needed
Look up number for kentucky bearing, elizabethtown ky.
They can lookup a bearing for you by the thickness, inside diameter, and outside diameter. They may even have a cross reference. If you dont have any luck finding their number, send me a note, and i will look it up for you. Typing on laptop in bed right now.
Old 12-12-2013, 11:53:35 PM
benrchestnut benrchestnut is offline
Numbers I have for the front wheel bearings and races are:
Part Industry # IH P/N
Inner Race 432 13207D
Inner Bearing 447 13211DB
Outer Race 3320 13201D
Outer Bearing 3379 13205D
You should have your supplier check the dimensions on these numbers as compared to your used parts.
Cow Needed? (IHC McCormick Milker) Plntdctr Hit & Miss Gas Engine Discussion 1 09-05-2011 03:41:58 PM
Mccormick M 3HP Help needed Here are the pics Dave L M Hit & Miss Gas Engine Discussion 5 08-24-2010 06:27:13 PM
Mccormick M 3HP Help needed Dave L M Hit & Miss Gas Engine Discussion 0 08-24-2010 03:24:59 PM
McCormick Deering help needed. Jordan Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 06-06-2008 04:04:22 PM
Help Needed McCormick Deering 11/2 hp. John Kaminsky Antique Engine Archives 6 04-23-2003 12:06:51 AM
