Go Back   SmokStak > SmokStak® Antique Engine Community > Hit & Miss Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Fairmont railway type 0D?
this thread has 4 replies and has been viewed 2076 times
Old 03-29-2014, 09:43:37 PM
Pwerwagn Pwerwagn is offline
Default Fairmont railway type 0D?
Hi all,
New to the forum. I read the sticky at the top, and it said to post topics like this in the "hit and miss" section, but I don't see it!! So if it needs to be moved, I apologize.
I have a fairmont type "0D" railway motor. It says 5hp, 8hp max. Group b, special 1. Serial number 79059. It has a big radiator on top.
Can anyone point me in the direction of an owners manual, parts break down, etc? Also, any idea what year? I did some searching and couldn't find anything pertaining to a type 0D.
Thanks,
Jeff
Old 03-29-2014, 09:52:18 PM
John Ledbetter's Avatar
John Ledbetter John Ledbetter is offline
Default Re: Fairmont railway type 0D?
Jeff Try this website. http://motorcar.winkworth.us/engines/engines_index.htm
http://2enginejohn.blogspot.com
Old 03-30-2014, 10:16:25 AM
Thanks john!
Old 04-01-2014, 04:00:21 PM
Exclamation Re: Fairmont railway type 0D?
Oil-Fuel ratio 16:1, using SAE 40 Non-Detergent oil. DO NOT use modern 2 stroke oil, as it will starve the rod and piston for oil. Mix oil and gas well before putting in tank, if left to sit more than 2 weeks, shake engine/tank well to re-mix fuel and oil. Use high test gas, as it has less alcohol in it,and it will not degrade as fast as regular E-10 crap gas. If engine is to sit more than 30 days, be sure to drain tank, and run engine until it quits, even using choke. The carb is made of poor quality aluminum and brass parts, which will eat each other up if exposed to phase seperated gas.
Old 09-07-2014, 08:59:15 AM
gt4 gt4 is offline
Hi, do you know if there is a Fairmont Type PHB and its a 4 hp serial #45127 or 43127. Thanks
fairmont type Q hit and miss kwwurm Hit & Miss Gas Engine Discussion 2 09-22-2013 11:19:50 AM
Fairmont Type C5 S. swick Unidentified Engines 4 11-27-2011 11:21:58 AM
Fairmont Railway Engine Questions wsrutherford Hit & Miss Gas Engine Discussion 11 05-04-2009 12:08:06 AM
railway engine, not a Fairmont Marty Antique Engine Archives 14 06-26-2003 03:34:41 PM
FAIRMONT RAILWAY ENGINE DENNIS WILKENING Antique Engine Archives 3 02-16-2000 10:05:17 PM
