Early bike motor? You tell me
this thread has 10 replies and has been viewed 1899 times
Old 05-04-2014, 05:12:53 PM
Matt1931's Avatar
Matt1931 Matt1931 is offline
Default Early bike motor? You tell me
Frame looks like BSA engine is way cool but not sure if it goes with frame. Email me and I can send more pis
Old 05-04-2014, 05:40:21 PM
Doug Tallman Doug Tallman is online now
Default Re: Early bike motor? You tell me
Gravely made a T head engine similar. Can't see enough to tell.
The Following User Says Thank You to Doug Tallman For This Post:
Old 05-04-2014, 06:30:26 PM
Matt1931's Avatar
Has a kick starter in the box it came with
Old 05-04-2014, 06:41:27 PM
Elden DuRand's Avatar
The head is Gravely. If it fits the block, it's for a Gravely Model L walk-behind tractor.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 05-04-2014, 06:59:21 PM
ShaneZahn ShaneZahn is offline
I also, was thinking it is for a Gravely walk behind tractor.
If I am not mistaken, the motor is a Kohler.
I don't know what the arrangement between Kohler & Gravely was. Did gravely use kohler engines exclusively.
I've never saw a kick start gravely tractor. So that might not be for the engine at hand.
The Following User Says Thank You to ShaneZahn For This Post:
Old 05-04-2014, 08:20:55 PM
RSCurtis RSCurtis is offline
That's a Gravely-built T-head engine.
The Following User Says Thank You to RSCurtis For This Post:
Old 05-04-2014, 08:37:16 PM
BSA never made a T head that I know of. Looks Gravely to me.
The Following User Says Thank You to beezerbill For This Post:
Old 05-04-2014, 08:54:58 PM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
It's a model L Gravely engine built by Studebaker.
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
The Following User Says Thank You to Preston Wells For This Post:
Old 05-04-2014, 09:06:47 PM
docgee docgee is offline
From what I can see it looks like a 500cc BSA thumper I use to race one good bike with a little work.
The Following User Says Thank You to docgee For This Post:
Old 05-04-2014, 09:19:49 PM
gambitace71 gambitace71 is offline
hi,that is a model L gravely engine for shure.Not bsa.the engine is fed oil from the gear box.you would need the gear box to run the engine.or fabricat an oil sump and a pump.thanks ken
The Following User Says Thank You to gambitace71 For This Post:
Old 05-05-2014, 06:54:08 AM
James Bosma's Avatar
James Bosma James Bosma is offline
Definitely Gravely model L 5.5 hp You can see the shaft and block that drives the mag in your pic.
The Following User Says Thank You to James Bosma For This Post:
Doing an Trick with my Motor Bike Brothers Clemens YouTube Old Iron Videos 2 03-30-2014 06:51:19 PM
Safticycle Sportster motor bike dw1973 Butt Buggys, Scooters, 4 Wheelers 0 06-05-2013 10:12:30 AM
travis bike motor Ed Radtke Garden Tractors and Mowers 3 12-26-2011 08:10:12 AM
Early head lamp for car or bike? Nathan Grissom Antique Autos and Trucks 7 04-29-2011 09:04:12 PM
Antique bike motor Tim Heck Antique Engine Archives 0 12-06-1999 11:42:04 PM
