'M' Oil Pull Fuel Tank
this thread has 8 replies and has been viewed 1640 times
Old 05-08-2014, 04:55:33 PM
Default 'M' Oil Pull Fuel Tank
What is involved in removing the main fuel tank from a 20-35 'M' Oil Pull? I seem to recall that they do not just come out without some other work. Friends have a bad leaker.
I see on Engineads that Biewer's have a pretty good looking 'M' with a fuel tank on the platform.
http://www.enginads.com/classifieds/...t/98682/cat/10
That's interesting!
Thanx.
RM.
The Following 2 Users Say Thank You to G Willikers For This Post:
Old 05-08-2014, 06:34:45 PM
Bubbles Bubbles is offline
Default Re: 'M' Oil Pull Fuel Tank
It comes out from underneath only.
The Following 2 Users Say Thank You to Bubbles For This Post:
Old 05-08-2014, 09:23:42 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
... and that involves getting the axle and "wishbone" out of the way, I think.
The Following User Says Thank You to Jon Nessel For This Post:
Old 05-08-2014, 09:38:12 PM
Gene Williams Gene Williams is offline
You need to remove the wishbone and can leave the axle IF you can jack the front end up high enough so the tank can slip out going forwards. Be sure to block the rear wheels really well of you do it this way as the front end will need to be up in the air quite a long ways. If you decide to make a new tank have one rolled a little smaller (just and inch or so) and it will be much easier to get in or out. I can't remember, but I think the tank will come out the top after the radiator is removed. Maybe Jason can chime in here.
The Following User Says Thank You to Gene Williams For This Post:
Old 05-08-2014, 10:14:47 PM
It's not a picnic but there are worse things to do on a Rumely.
Getting the wishbone out of the way isn't that big a deal and once the front end is jacked up it's not so bad a job although your back may feel differently.......
Old 05-08-2014, 10:29:39 PM
Jason W Jason W is offline
I was able to remove the fuel tanks in my 25-40 Rumely's from the top after I'd taken off the radiator and water tank. I think there was some front end jacking involved there as well but not nearly as much as taking it out the bottom.
The Following User Says Thank You to Jason W For This Post:
Old 05-08-2014, 10:37:50 PM
Thanks guys. I have forgotten a lot of this now. I think on my old X, I could lift it up once the cooler, etc. was off. I seem to recall that my old M was going to be a pig and I fixed the tank in place by rolling it around between the frames as much as possible. But that seems to be all out of the memory banks now!
Old 05-09-2014, 07:28:49 PM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
So is the fuel tank the same on the M and X? I need one for my X.
Thanks.
Keith
Keith Kinney
www.HerculesEngines.com
Old 05-09-2014, 08:20:22 PM
I think so. I made new tanks for my X. I had 10ga steel rolled to my desired diameter and length and I had 2 circles cut for ends. I welded them together myself. Don't quote me but I think it was only about $125 for material per tank. Once I got fittings in I pressure tested to about 50psi for any leaks and it went in the tractor.
The Following 2 Users Say Thank You to Jason W For This Post:
Rumely Oil Pull Fuel 2030rumely Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 20 01-04-2014 12:43:46 PM
Fuel tank - desolder tank halves to repair? KD5BYB Small Air Cooled Gasoline Engines 8 12-04-2011 06:08:58 PM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
Fuel mixture when working an Oil Pull A Martinson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 51 11-22-2008 02:21:52 AM
Oil Pull 16/30 H, Fuel Press Prob Nik O. Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 04-09-2008 01:18:56 PM
