GMC 1500 P/U Fan Switch
this thread has 3 replies and has been viewed 2464 times
Old 05-09-2014, 04:54:17 PM
John Newman, Jr.'s Avatar
Default GMC 1500 P/U Fan Switch
I have a '95 GMC 1500 pick-up. The cab heater / A.C. fan only works on "High". What would cause this? Is there some kind of resistor block that regulates the lower speeds? Are they known to fail? Where is it located? Should be able to tell if it has burned out if I can find it. I have pulled the plug off the back of the switch and reattached it hoping it was just a dirty connection, but that did not help.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 05-09-2014, 06:22:03 PM
JHoward JHoward is offline
Default Re: GMC 1500 P/U Fan Switch
On the earlier Chevy models there was a couple of small wire wound resistors on the backside of where the plug attached (inside the heater box assembly).
Jhoward.
Old 05-09-2014, 06:55:32 PM
MoRo's Avatar
MoRo MoRo is offline
The "High" setting is on a separate circuit from the others. Have you checked your fuses? (Dumb question, I know.)
Old 05-09-2014, 08:46:26 PM
Jake Jacobs Jake Jacobs is offline
This what you need to know. http://www.youtube.com/watch?v=gj4hw-HR3n4
Kohler - MPAC 1500 - Ethernet Connection joejack Kohler Generators 14 04-02-2014 03:40:16 PM
Bedford Model 1500 Air Cooled bigGURN Small Air Cooled Gasoline Engines 2 09-27-2012 08:25:55 PM
Tecumseh 1500? info/specifications wvukidsdoc Small Air Cooled Gasoline Engines 0 05-13-2012 03:27:17 AM
kohler 1500 watt light plant Fred Kohler Generators 1 03-17-2002 01:33:33 PM
