Tiny Tim Battery Charger
this thread has 7 replies and has been viewed 2664 times
Old 09-22-2014, 09:54:03 PM
bartlett0815 bartlett0815 is offline
Default Tiny Tim Battery Charger
Thanks for the replies when I posted about this unit a few months ago. I took off the gas tank and carb for cleaning and found what appears to be original pale green paint underneath, if that means anything. I jumped the unit using a car battery to the pos/neg posts on the side, pushed the relay in and it fired right up. Removing the jumper cables, it would run on its on for a couple of minutes, then shut itself down. I got 9 - 11.8 volts output on the post side, but no voltage on the wires beneath the relay on the other side. Any ideas on how this thing is supposed to be hooked up to the starting battery and the batteries being charged?
Thanks,
Kevin in Wilmington, NC
Old 09-23-2014, 08:49:30 PM
Default Re: tiny tim battery charger
I got home from work this afternoon and tinkered with this unit some more. I disconnected the cutout relay and hooked a 6V battery directly to the coil, started it with a rope on the pulley and got no output voltage, though it was running fine. Touching the disconnected wire back to the cutout relay caused the relay to close contacts itself and I got crazy jumping voltage readings on the posts on the other side. I only did this for a few seconds so I hope I didn't fry anything. Electricity is not one of my strong points. Still hoping to get this thing figured out. Whether it works or not, its still good to hear this little engine running.
Kevin in NC
Old 09-24-2014, 01:39:53 PM
Fred M. Fred M. is offline
Kevin-
I found a reference to Army Technical Manuial TM-5-5365, for the Tiny Tim Generator. It may have been posted here last year.
I did a quick search, but was not able to find a copy of that TM on line.
At the time, I downloaded several photos, including pages from the TM. I am attaching two here, in case they might apply to your battery charger.
Fred
ID:	206793   Click image for larger version
Old 09-24-2014, 09:27:38 PM
Fred,
Thanks for the wiring diagrams. Maybe I'll get it figured out now.
Thanks,
Kevin
Old 09-24-2014, 09:35:09 PM
Is this the same thing as the Montgomery Wards Airline generator? I have 1 and have wanted a diagram for a long time.I hope it is the same or at least similar enough.
http://www.smokstak.com/forum/showthread.php?t=114176
Here is the thread on mine.
Old 09-25-2014, 09:44:27 PM
I saw one like yours at Denton this summer but it looked to be in pretty sad shape. Here's a photo of mine.
Old 09-26-2014, 02:39:34 AM
John Newman, Jr.'s Avatar
I may be mistaken, but I think that is a Delco "Little Joe" battery charging generator. While similar in appearance, they are two different animals.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-17-2017, 10:13:13 PM
Tim Venetis Tim Venetis is offline
Hi I was wondering if you could convert a 6 volt tiny tim generator to charge a 12 volt battery by changing the voltage regulator? Thanks.
Tiny Tim Generator/Battery Charger John Schwiebert Generators & Electric Motors General Discussion 23 05-18-2017 01:21:13 PM
Tiny Tim Battery Charger Wiring skeeter Generators & Electric Motors General Discussion 0 02-24-2011 12:38:49 AM
Tiny Tim battery charger JBailey Small Air Cooled Gasoline Engines 3 05-05-2005 08:22:35 AM
Correct wiring for Airline (Tiny Tim) charger? DannL Generators & Electric Motors General Discussion 2 03-01-2005 07:16:40 PM
Ward's Charger, Tiny Tim Steve Wright Generators & Electric Motors General Discussion 3 07-22-2004 07:59:30 AM
