Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Kohler Generators
Kohler Generators
Kohler Kohler 300W Belt Generator
this thread has 3 replies and has been viewed 1796 times
Old 10-07-2014, 03:57:32 PM
Heelerman Heelerman is offline
Default Kohler Kohler 300W Belt Generator
Bought this at a sale with a 8HP Briggs and Stratton motor. Didnt look at the output until after the sale, 300W. Curious to see if anybody collects these.
thanks I appreciate your help.
Old 10-07-2014, 08:09:51 PM
LWB250 LWB250 is offline
Default Re: Kohler Kohler 300W Belt Generator
Sure it's not a 3000 (3kW) watt generator?
A 300 watt generator would need nothing approaching an 8HP engine.
There should be a nameplate on it. Post a picture if possible, tat way we can tell for sure.
I don't know about prior to the 1970s, but in the 1980s there were two two bearing generators that were sold, a 3.5kW and a 5kW.
I'm betting it's a 3000 watt generator.
Dan
Old 10-07-2014, 08:59:54 PM
Being a belt drive someone COULD have connected a 300 watt head.... But if a factory model I'd think closer to 5.5KW. My 9hp Lombardini diesel cranks out a solid 6.5KW.
I agree that pics would help clarify question.
Doc
Old 10-09-2014, 10:46:38 AM
Kohler never made a two bearing generator of that size that I am aware of. Only two bearing generators I ever saw when I worked there were the 3.5kW and 5kW that were variants of the same sized portables of the time.
Dan
The Following User Says Thank You to LWB250 For This Post:
Kohler 3.5RM62 Spec. 620 H.3.4.5.7 with kohler A-23858 information bobfish1 Kohler Generators 2 08-13-2013 10:21:18 AM
FM Mag on Kohler Generator John Newman, Jr. Magnetos, Ignition Coils and Spark Plugs 6 08-16-2010 11:05:48 PM
New flat belt for Kohler? MerlinHanson Kohler Generators 2 10-18-2008 08:37:11 PM
Kohler Light Plant, flat to v belt transition Larry K Kohler Generators 7 10-15-2008 12:51:48 AM
Kohler 1.5 KVA generator richard cleveland Kohler Generators 7 03-02-2007 01:34:43 AM
