Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
REX M20 water trash pump
this thread has 3 replies and has been viewed 1345 times
Old 05-14-2015, 07:55:23 PM
Windmill Bob Windmill Bob is offline
Default REX M20 water trash pump
Bought this as a project (not running, motor stuck) several years ago. Finally started working on it.
It is powered by a Wisconsin AHH gas engine. Got it unstuck and eventually got carb cleaned with Seafoam after letting set for months, put diesel fuel in the engine cylinder. Never thought I would get it started but lucked out after spending much time.
I need to know how the oiler or grease spring loaded canister works to lube the pump shaft. I took apart and cleaned old gunk out (grease). There is a screw cap on top of the small tube canister that has a T for screwing the spring inside the canister? A small diameter tube runs from this to the pump shaft area.
Is this some kind of pressure greaser and just keep turning the T screw to apply pressure to inject grease to pump shaft or bearings????
Would appreciate help as I do not want to run the pump without lubrication.
Thanks,
Windmill Bob
Old 05-15-2015, 09:33:09 AM
Heins Heins is offline
Default Re: REX M20 water trash pump
Here is a picture of my pump, it has a AHH engine that I put a flat belt pulley on and powered it with a 10 HP Fairbanks oil engine to pump water in our local parade. It has a grease seal which work good, just grease it. Is your pump like this? There is a short video on Smokstak if you want to see it pumping water.
Old 05-15-2015, 03:12:40 PM
Larry Evans's Avatar
Larry Evans Larry Evans is offline
Windmill Bob
Sounds like you might be describing this type of automatic grease cup. The attached images are from a 1908 Lunkenheimer catalog. They made several different versions of this one but all operated about the same. Basically the idea is to turn the handle up to the top to allow the spring to push grease into the bearing when running and run the handle down to lock the piston when not not in operation. Take a close look at the images and what I am saying might make sense.
If your greaser is different try to post a picture of it.
Larry
ID:	225484   Click image for larger version
ID:	225485   Click image for larger version
Larry Evans
http://www.oldengine.org/members/levans/
The Following User Says Thank You to Larry Evans For This Post:
Old 05-18-2015, 06:48:18 PM
Thanks for reply. No, mine does not look like yours. Mine is mounted on a 2 wheel cart the can be pulled behind a pickup or small truck. Was owned by a County close to us and they put it on an auction several years ago.
Maybe it will not pump once I get it greased and running. Impeller (spelling?) could be bad but it does turn when I crank the engine.
Goulds Trash/Mud Pump Roger Eldred Hit & Miss Gas Engine Discussion 3 08-09-2011 09:39:18 PM
Wisconsin motor with Rex trash pump ditchwitch 42 Wisconsin Engines 20 10-09-2009 07:49:33 PM
Novo Trash Pump Ed Allandar Hit & Miss Gas Engine Discussion 3 04-20-2008 10:03:21 PM
Trash Pump diaphram Norm Antique Engine Archives 2 07-24-2000 03:14:23 AM
Domestic # 3 Diaphram/Trash pump. Paul Spence Antique Engine Archives 0 11-24-1999 06:01:36 AM
