Kohler Kohler K 161 T (1978) on Troy Built Tiller weak spark
this thread has 3 replies and has been viewed 1973 times
Old 06-07-2015, 09:59:08 PM
youngbill1946 youngbill1946 is offline
Default Kohler Kohler K 161 T (1978) on Troy Built Tiller weak spark
I have 1978 Kohler K 161 T which I have replace points(set at .20 ), condenser, and coil with Oregon 33-363. Very weak spark. Will light neon tube but won't start engine or jump a gap on spark tester. How do I check magnets to make sure they are good?
Old 06-09-2015, 03:37:20 AM
cobbadog cobbadog is offline
Default Re: Kohler Kohler K 161 T (1978) on Troy Built Tiller weak spark
I am not familiar with your engine but I can still throw some ideas at you. Is the coil adjustable? eg; can it be moved closer or further away from the magnets on the magneto? If it is adjust to being about 0.008" and see if it improves. Clean the points so that they are free of any contaminants, I use either methylated spirits or white spirits. If you hold a screw driver against your magnets and try to pull it away and there is resistance they are good. If it comes away easily they are weak. I have found it rare to find that these loose their strength very often but if they have they can be recharged.
Old 06-09-2015, 04:14:24 PM
gdstew gdstew is offline
A quick "Google" search of the Oregon coil shows that is for a Tecumseh engine. Does it have the same specs as Kohler? What condenser are you using, Kohler or Tecumseh? They may all have the same specs, but I don't know. New Kohler points often need to be cleaned before installing, they had a protective coating on them. You might want to try cleaning the points and installing a condenser that matches the Tecumseh coil.
The Following User Says Thank You to gdstew For This Post:
Old 06-10-2015, 09:38:11 AM
Found the problem. Bad ground on condenser. Cleaned grease and crude from block and bolt and finally had great spark. Starts great. Thanks to all replies. Bill
Kohler DE1 built 1939 Bill Hazzard Kohler Generators 23 05-15-2015 09:20:05 PM
troy bilt tiller with Tecumseh id help Mikey NY Garden Tractors and Mowers 15 05-19-2013 09:31:49 PM
Troy Built Tiller loggerhogger Small Air Cooled Gasoline Engines 5 06-04-2012 08:52:52 PM
Cross referencing Troy built Tiller part numbers flywelder Garden Tractors and Mowers 1 05-19-2011 07:51:58 PM
Troy-bilt Tiller Parts Sonny Reese Garden Tractors and Mowers 7 05-19-2011 12:22:56 PM
