Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Model 82 Teardown Question
this thread has 2 replies and has been viewed 1374 times
Old 12-05-2015, 11:02:23 PM
kleinkaliber kleinkaliber is offline
Default Model 82 Teardown Question
Never played with an 82 before. How does one go about disassembling the main bearing housing/remove the crankshaft? Have the mag assy. off, but don't want to go farther without a little direction.
Old 12-06-2015, 08:27:06 AM
Clement Rook Jr. Clement Rook Jr. is offline
Default Re: Model 82 Teardown Question
after the flywheel and backing are off, just remove the four bolts holding the main bearing
on. the bearing and crank shaft should pull straight out.you may have to pry the gasket away from the main bearing and block. thats all there is to it. have fun!!!!
Old 12-06-2015, 12:52:25 PM
Ok, I'll tear into it. Engine was found in a ditch. Very rusty. No fun to pull something apart only to find I skipped a step and hurt something.
Little crawler teardown wilson Ross Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-26-2010 01:09:21 PM
Cam timing after teardown gruby26 Small Air Cooled Gasoline Engines 3 01-18-2009 09:21:11 AM
Tecumseh H30 teardown and overhaul squarend Small Air Cooled Gasoline Engines 9 05-10-2008 11:35:27 PM
Teardown to remove sludge? Orrin Iseminger Antique Engine Archives 8 01-05-2000 08:41:29 PM
