1948 International KB1 Truck
this thread has 2 replies and has been viewed 1046 times
Old 08-13-2016, 01:07:23 PM
DavidRaines DavidRaines is offline
Default 1948 International KB1 Truck
Got new buttons for the panel, gas, choke and lights. The light button/switch was replaced by a more modern one. Should I find an original, how hard are they to work on? If they don't work are they toast?
Have the button for it but need the switch.
Thanks......Dave
The Following User Says Thank You to DavidRaines For This Post:
Old 08-14-2016, 08:26:49 AM
78Loadstar 78Loadstar is offline
Default Re: 1948 International KB1 Truck
Been a while but if I remember correctly there are metal tabs that hold a bakelite board with the wiring connections attached to it. Bend the tabs back ,remove bakelite, clean connections and reassemble. Should not be too hard to find one. I have one on a KB-5 outback of the shop.
Another idea would be to use your knob on the new switch if possible.
Dennis
The Following 2 Users Say Thank You to 78Loadstar For This Post:
Old 08-14-2016, 09:32:22 AM
^ Yup. standard automotive design from the period. Open them up, clean the surfaces and grease the guts. Also solder the flags to the rivets to eliminate the resistance point that heats up and burns the fiber plate. They'll be good for another 50 years.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
Hercules RXLDH engine out of 1948 Pirsch fire truck? Jason Barnett Antique Autos and Trucks 17 09-19-2017 08:19:51 AM
1948 International KB-7 truck balcom farms Antique Autos and Trucks 4 02-18-2015 11:13:16 PM
Very low milage 1948 Chevy truck Culy Antique Autos and Trucks 9 12-19-2014 10:11:23 PM
1919 International Truck old rancher Antique Autos and Trucks 4 06-02-2014 09:01:54 AM
Old IHC International truck David Nicolson Hit & Miss Gas Engine Discussion 4 02-03-2005 07:28:50 PM
