Fairbanks Morse Air Compressor Engine
this thread has 13 replies and has been viewed 2091 times
Old 09-30-2017, 08:06:21 PM
Todd Hodges's Avatar
Todd Hodges Todd Hodges is offline
Default Fairbanks Morse Air Compressor Engine
Found this engine on local Craigslist is has a good solid base 3hp pumps air really good shape . If I looked @ serial # correctly it's 1926 model. Me and my son clean the spark plug and oiled and greased it put some gas in starting tank fired right up . I usually don't have that kind of luck here's a few pictures. Notice on picture #3 there is a tab on the spark plug wire tower on mag there's is that spark plug gap setter or what???
Name:	Fm aircompressor 001.JPG
ID:	292591   Click image for larger version
Name:	Fm aircompressor 002.JPG
ID:	292592   Click image for larger version
Name:	Fm aircompressor 003.JPG
ID:	292593   Click image for larger version
Name:	Fm aircompressor 004.JPG
Old 09-30-2017, 09:13:31 PM
Allan Wright Allan Wright is offline
Default Re: Fairbanks Morse Air Compressor Engine
Nice find Todd!!
You need to go buy a lottery ticket tonight.
The Following User Says Thank You to Allan Wright For This Post:
Old 09-30-2017, 09:55:06 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Wow, that is nice. Bring it to Temple next week. I think you are correct about the tab being a gap setter. Been a long time since I have seen one.
Old 08-11-2018, 10:05:52 PM
Ok been working on this Engine and compressor engine runs great But the compressor has a internal freeze crack on the head tried water glass or seal up it does not seal the crack once’s the compressor builds up pressure so ?? is does anyone have a head for this compressor size is 3 3/4 X 4. Any help would be appreciated thanks
Old 09-21-2018, 12:15:50 PM
Well no luck repairing this head So I went shopping Jon Rozevink had one in he's parts Now I'm pumping air that has no water in it My ?? now is does the three nuts above the reid valves need to be tight or just hand tight is that the way you adjust how the air production of compressor Does anyone have a manual on this compressor or does anyone of repro of these manuals
Old 09-13-2019, 02:58:59 PM
Photo Re: Fairbanks Morse Air Compressor Engine
Well I finally got everything done with this got it running. I got pop-off valve set at 120 psi and the I closes at 100psi I think that’s safe enough. What do y’all think https://youtu.be/nWymYxuVt0Y
The Following 8 Users Say Thank You to Todd Hodges For This Post:
Old 09-13-2019, 03:14:57 PM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
Todd, looks great. My son called me today and said " saw these old engines on 287 better go and see" yep i told him i been there, ha
The Following User Says Thank You to Gene Fisher For This Post:
Old 09-13-2019, 03:54:55 PM
Ed Noli's Avatar
Ed Noli Ed Noli is offline
Todd, there should be a water hopper on the head of the compressor. I could never find one for mine, and ended up fabricating one.
The Following User Says Thank You to Ed Noli For This Post:
Old 09-13-2019, 04:14:09 PM
What does the hopper look like I’ve never seen one you have any pictures
Old 09-13-2019, 10:15:45 PM
Foseng Foseng is offline
Dave
Laoag City
Philippines
The Following 3 Users Say Thank You to Foseng For This Post:
Old 09-14-2019, 11:50:03 AM
Ed Noli's Avatar
Here is the one I fabricated.
The Following 2 Users Say Thank You to Ed Noli For This Post:
Old 09-14-2019, 08:53:51 PM
Lou Quirch Lou Quirch is offline
I have one of those to start our S M Jones oilfield engine. It is a great running setup.
Lou
Old 09-25-2019, 05:27:31 PM
Added air horn and whistle Just thought I’d share video with y’all may add the other horn later https://youtu.be/6owDHpSH42Y
The Following 3 Users Say Thank You to Todd Hodges For This Post:
Old 09-25-2019, 09:42:03 PM
Todd, looks like you are ready for the Temple show. See you there early on Friday. Jim has the big Fairbanks jacked up to level and ready to run.
Fairbanks Morse Model Z Hit and Miss Engine plus separate FM compressor Rich in SLC Hit & Miss Gas Engine Discussion 9 04-13-2017 12:36:34 AM
Fairbanks Morse Model Z Hit and Miss Engine plus separate FM compressor Rich in SLC Hit & Miss Gas Engine Discussion 1 11-02-2016 08:27:48 PM
Fairbanks Morse engine and Compressor Greg Mosley Hit & Miss Gas Engine Discussion 2 09-05-2016 06:11:29 PM
Fairbanks Morse vertical cylinder 3x3 1/2....is it an engine? compressor? A pump? leeg Unidentified Engines 5 07-02-2013 01:27:23 AM
Fairbanks Morse Compressor Eric Swab Hit & Miss Gas Engine Discussion 10 05-05-2009 08:19:29 PM
