New Platform
this thread has 8 replies and has been viewed 1363 times
Old 11-26-2017, 06:38:47 PM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
Default New Platform
I just finished a new platform for my Deutz Otto four hp E12 made in 1912. It has four 8"cast wheels under the corners for moving on the concrete floor and will use plywood at shows if a hard surface is not available. Four inch square tubing and heavy channel across under each end of the engine with angle iron around to bolt the oak planking to. It had nice oak skids but i wanted to make a more pleasing display for the 105 year old engine as i thought it deserved.
ID:	297007   Click image for larger version
ID:	297008   Click image for larger version
ID:	297009   Click image for larger version
Old 11-26-2017, 07:04:25 PM
Target Driller Target Driller is offline
Thumbs up Re: New platform.
The base looks great Gene.
The Following User Says Thank You to Target Driller For This Post:
Old 11-26-2017, 07:43:26 PM
WCraig WCraig is offline
Default Re: New platform.
Looks great. Love the stain color.
The Following User Says Thank You to WCraig For This Post:
Old 11-26-2017, 08:22:59 PM
Brickman's Avatar
Brickman Brickman is offline
looks very nice gene
The Following User Says Thank You to Brickman For This Post:
Old 11-26-2017, 11:41:22 PM
Chris Epping's Avatar
Chris Epping Chris Epping is offline
Default Re: New Platform
Nice job Gene!
The Following User Says Thank You to Chris Epping For This Post:
Old 11-28-2017, 09:21:11 PM
D Reachard D Reachard is offline
Great Job---What type of mag is on your engine? Could it be a SR Simms Bosch?
Old 11-29-2017, 08:15:17 PM
The magneto is "Apparat KC #8733 Patent"
Old 11-29-2017, 08:25:16 PM
That old girl has a base to match her majesty.
The Following User Says Thank You to Pat Barrett For This Post:
Old 12-04-2017, 09:31:31 PM
I took the magneto off and on the other side it says "Gasmotren Fabrik-Deutz"
Perfect Example of Why Someone Should ALWAYS be on the Platform Beth V Steam Stationary Engines, Traction Engines 75 09-22-2017 12:49:43 PM
Tractor Balancing Platform Gary Pflum Antique Farm Tractors 3 03-20-2015 04:30:21 PM
Platform Construction Beth V Steam Stationary Engines, Traction Engines 4 04-15-2014 09:43:41 PM
18-32 Case Platform Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 12-18-2012 05:29:49 PM
