Field-Brundage, Racine Sattley and Sattley Engine Registry
this thread has 63 replies and has been viewed 4579 times
Old 01-12-2019, 06:25:14 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is online now
Default Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
Originally Posted by CODY K View Post
Denis, the flywheel reads TA16444.
The serial letters and numbers TA16444 is sure indication that your engine was built by Nelson Bros. in Saginaw Michigan. People often refer to these as the "New Sattley" engines. They were built by Nelson Bros. but sold by Montgomery Ward.
Denis Rouleau
Old 01-24-2019, 06:48:34 PM
Mike Linder Mike Linder is offline
Are the Page engine made in Canada that are copied from Field-Brundage have the same size engines flywheels and hp as the engines made in the USA?
Old 01-24-2019, 06:57:21 PM
You guys will have to help me with that one. This is the first time I hear of a made in Canada "Page" copied from Field-Brundage engines.
Denis Rouleau
Old 01-25-2019, 11:16:22 AM
BakerCollector BakerCollector is offline
Does this appear to be a Field Brundage engine? There is no tag. I have another one listed on my United registry tagged United but I haven't been able to prove the builder yet.
Dale Salmon
United Engine Registry & Website Caretaker
www.AUGERMO.com
The Following 2 Users Say Thank You to BakerCollector For This Post:
  #25
Old 01-25-2019, 06:00:07 PM
CODY K's Avatar
CODY K CODY K is offline
Denis, My sattley you have put in your registry is put down as a hit n miss. It is a throttler. I see a few other throttlers that are put down as a hit n miss as well! Cody
Old 01-25-2019, 06:47:54 PM
Please tell me which engines (need serial number to make changes) are throttlers and not H&M.
Thanks!
Denis Rouleau
Old 01-25-2019, 06:58:53 PM
Skip Landis Skip Landis is offline
That engine looks like a type"B" united. skip
The Following User Says Thank You to Skip Landis For This Post:
  #28
Old 01-25-2019, 09:00:37 PM
That's exactly what it is (Type B United) but I'm looking for the manufacturer. United never actually made an engine they only sold other companies engines. It's been suspected that F&B produced these for United but nothing set in stone on that theory. Was looking to see if any F&B exists that look identical with similar serial numbers to try and 'confirm' that suspicion.
Dale Salmon
www.AUGERMO.com
Old 01-25-2019, 11:31:13 PM
No Field-Brundage built engines look anything close to this United type B.
The Following User Says Thank You to Denis Rouleau For This Post:
  #30
Old 01-26-2019, 12:21:36 AM
CODY K's Avatar
Denis the ones I noticed are # TA16444, U1125, U4117, U4956. The ones with the big square looking carburetor are throttle governed!
The Following User Says Thank You to CODY K For This Post:
  #31
Old 01-26-2019, 11:49:34 AM
Does anyone know of an engine that was made that resembles the Type B United? Another suggestion was Bluffton built but I haven't seen one of those either to compare.
Dale Salmon
www.AUGERMO.com
Old 01-28-2019, 09:04:25 AM
I had not received any more Field-Brundage info to add to the registry in the last 2 months but this all changed yesterday when I was sent info on engines #2947 and #3433 which you can look up here:
http://buzzcoil.brinkster.net/Field%...e/page101.html
Anyone else have a Field-Brundage to add to the registry?
Thank you!
Denis Rouleau
Old 01-28-2019, 12:23:20 PM
Denis, here is a 3 hp that i have, #10233. I don't have pics. It is throttle governed, missing webster & bracket. I would sell it for $195 if anyone wants it. skip
Old 01-28-2019, 02:37:02 PM
Originally Posted by Skip Landis View Post
Denis, here is a 3 hp that i have, #10233. I don't have pics. skip
Did you get the serial number off of a name tag or from somewhere else on the engine? That serial number is close to the last number used on a Field-Brundage.
Denis Rouleau
Old 01-28-2019, 08:37:04 PM
Culy's Avatar
Culy Culy is offline
Here is another one for your registry.
ID:	327388   Click image for larger version
ID:	327389   Click image for larger version
ID:	327390   Click image for larger version
The Following User Says Thank You to Culy For This Post:
  #36
Old 01-29-2019, 12:37:52 AM
It came from the tag
  #37
Old 01-29-2019, 08:08:23 AM
I need to see a picture of the name tag for the registry. If you don't have one now, I'll settle for one later.
Thanks!
Denis Rouleau
---------- Post added at 08:08:23 AM ---------- Previous post was at 07:30:46 AM ----------
Your "Racine Sattley" is now in the registry here:
http://buzzcoil.brinkster.net/Field%...e/page104.html
Thank you!
Denis Rouleau
Old 02-05-2019, 06:58:36 PM
David Babcock David Babcock is offline
Smile Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
Heres a photo of my "naked" field. Stripped paint, pins , bushings and decals. Serial# 8739. For the registry. Db.
ID:	327974   Click image for larger version
The Following User Says Thank You to David Babcock For This Post:
  #39
Old 03-29-2019, 01:10:03 PM
Question Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
Denis, ive always suspected that the "new sattley " engines were built at the old field plant in jackson and not nelson bros. Saginaw, as most think. I think this advertisment may prove this? Db.
Old 03-29-2019, 03:20:33 PM
Originally Posted by David Babcock View Post
Denis, ive always suspected that the "new sattley " engines were built at the old field plant in Jackson. Db.
David, do you know if this is an ad from a 1923 magazine OR a pamphlet that came from WICO?
Denis Rouleau
Feild & Brundage / Racine Sattley BobRR Hit & Miss Gas Engine Discussion 63 05-09-2019 10:43:44 AM
Sattley, Field Brundage what can you tell me? Will Batty Hit & Miss Gas Engine Discussion 9 01-30-2019 09:54:00 AM
Field Brundage, Racine Sattley, OR BOTH? greenmars2 Antique Engine Photos 4 04-29-2016 01:04:50 AM
1 1/2 hp Sattley (Field-Brundage) repops? Eric McKenna Hit & Miss Gas Engine Discussion 0 07-11-2015 07:06:05 PM
Indentifying a Field Brundage / Sattley Harry Hit & Miss Gas Engine Discussion 9 08-07-2008 02:17:36 PM
