Field-Brundage, Racine Sattley and Sattley Engine Registry
this thread has 63 replies and has been viewed 4568 times
Old 03-29-2019, 04:20:21 PM
David Babcock David Babcock is offline
Question Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
I dont know. It was found on the internet somewhere. Db.
Old 03-29-2019, 05:47:04 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
There is something fishy about this ad. It is obviously a "WICO" ad from after 1923. The Field-Brundage Co. no longer existed after 1916.
In this WICO ad they say that the "Field-Brundage Engine Works" were using WICO magnetos on their engines. To me "Field-Brundage Engine Works" did not build engines and it probably never even existed. I think WICO made up that whole story.
I still think that no Nelson Bros. were ever made at the Jackson factory.
Included if another WICO ad from that era.
Denis Rouleau
ID:	331655   Click image for larger version
The Following User Says Thank You to Denis Rouleau For This Post:
  #43
Old 03-29-2019, 07:20:55 PM
Smile Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
The fine print does say : Manufacturers for montgomery ward. Even tho montgomery ward owned the plant at that time, maybe they didnt want the world to know that the old field brundage plant got bought out?? To me the new sattley looks more like a field engine than a nelson bros. Just my feelings. Maybe we will never know. Db.
Old 03-29-2019, 10:20:43 PM
Originally Posted by David Babcock View Post
To me the New Sattley looks more like a field engine than a nelson bros. Just my feelings. Maybe we will never know. Db.
To me there are Field-Brangage engines, Racine Sattley engines, Sattley engines, then Nelson Bros. engines.
To me there is no such thing as a "New Sattley" engine.
Denis Rouleau
Old 04-12-2019, 05:22:02 PM
KenDawson KenDawson is offline
Dennis, sent you pictures of a 10 hp page Canadian sold field brundage serial number 3407 on the tag also the same on crankshaft on magneto side.Engine has a 6 1/2 inch bore 43 inch diameter flywheels the engine is identical to the 12 hp field brundage hit and miss flywheels have an ee 39 part number the 15 hp that I am trying to restore has a 7 inch bore and 39 inch diameter flywheels with part number EE 39. Using the detent off of the 10 to copy for the 15 as all part numbers are identical just different bores.
The Following 2 Users Say Thank You to KenDawson For This Post:
  #46
Old 04-13-2019, 08:23:23 PM
Originally Posted by KenDawson View Post
Denis, sent you pictures of a 10 hp page Canadian sold field brundage serial number 3407 on the tag also the same on crankshaft on magneto side.
Ken, can you double check the serial number in case it is 8407 instead of 3407. Both numbers would make sense but there would be several years between the two engines.
In the meantime, your engine's pictures can be seen here by anyone interested:
http://buzzcoil.brinkster.net/Field%...e/page110.html
Denis Rouleau
Old 04-14-2019, 04:07:23 PM
Doug Hanneman's Avatar
Doug Hanneman Doug Hanneman is offline
Hi Dennis,
I am sending some photos and information on my 1 1/2 HP Racine Sattley SN 18546 for your registry. I bought this engine in 1999 at the LeSueur swap and restored it in 2003. I was told it was made in 1917 but have no source. Also I started a thread on the Stak in February 2002 to determine the color and it was a long discussion and thought that it could be red or black but some folks that had several Racine Sattleys stated their earlier SN models with original paint were red so I painted mine red. It has always been a nice slow runner at shows and usually problem free.
Regards,
Doug
ID:	332718   Click image for larger version
ID:	332719   Click image for larger version
The Following User Says Thank You to Doug Hanneman For This Post:
  #48
Old 04-14-2019, 05:32:27 PM
Doug
Doug, I find your Racine Sattley looking good, even in red!
Here is a color photo from the Montgomery Ward 1916 Fall catalog. At $28.00 I'm thinking of ordering one or two!
The Following 2 Users Say Thank You to Denis Rouleau For This Post:
  #49
Old 04-14-2019, 08:22:38 PM
Dennis, looked at the page engine again it is 3407 on both ends of the crankshaft and on the tag.Years ago I think a lot of companies shipped parts to Canada as implement parts then they were assembled to skirt duties. Once went with a friend to Canada to pick up a 5 hp stickney engine the plate on the govenor cover read Ontario wind generator and pump co. Worried about bringing it back across the border problem solved when we took the plate of on the back side was the stickney plate duties solved. The page engine is the one Mike Linder asked about part numbers are all the same as field brundage engines.
The Following User Says Thank You to KenDawson For This Post:
  #50
Old 05-11-2019, 09:23:12 PM
Kvt Kvt is offline
I just purchased a Sattley, SN 58934, 1 1/2 HP,
Just got started on these engines
Have not even got it off the trailer yet when I noticed that someone had removed the mixer/carb and replaced it with a piece of copper pipe. So looking for 1. Pics of what is supposed to be there, and leads on where to find one.
KVT
The Following User Says Thank You to Kvt For This Post:
  #51
Old 05-11-2019, 10:13:05 PM
Can you post some pictures of your Sattley?
Thanks!
Denis Rouleau
Old 05-14-2019, 12:21:25 PM
Kvt Kvt is offline
Have to figure out how to insert an image. I have no place on the web to post them.
Old 05-14-2019, 06:43:51 PM
You can email your pictures to me directly at: buzzcoil2@videotron.ca
Thanks!
Denis Rouleau
Old 06-17-2019, 11:06:24 PM
Mike Linder Mike Linder is offline
Here are a couple of pictures of our 12 hp Field Brundage engine.
ID:	337360   Click image for larger version
ID:	337361   Click image for larger version
Old 06-18-2019, 09:42:03 AM
http://buzzcoil.brinkster.net/Field%...e/page101.html
I would like to add it to the registry above. Can you send me its data for the registry?
Thanks!
Denis Rouleau
Old 06-18-2019, 02:45:02 PM
Denis, I dont have a lot of info on the engine the tag is missing and there is no serial number stamped on the end of the crank. It has "12" part numbers on the main bearings and other parts and the guy we bought it from a few years ago claimed it to be a 12 hp engine. Your more then welcome to add it to your registry!
I see you have our 12 hp Sattley on there with pictures from the you tube video, I will send you a few better pictures of it.
The Following User Says Thank You to Mike Linder For This Post:
  #57
Old 06-19-2019, 10:02:33 AM
Here are pictures of a beautiful original little 1-1/2hp kerosene Sattley I saw and took pictures of at Coolspring:
http://buzzcoil.brinkster.net/Field%...e/page112.html
Denis Rouleau
Old 09-09-2019, 02:46:59 PM
McRoth McRoth is offline
Here's some picture of my new to me Sattley! I bought it at an auction in PA over the weekend. I can't make out much from the tag though. I'll look on the crank for a serial number tonight.
From what I understand it is a kerosene engine. It seems to be complete. I'm planning on restoring it.
Denis, I sent you these pics earlier today for your registry.
Thanks!
ID:	343586   Click image for larger version
ID:	343587   Click image for larger version
ID:	343588   Click image for larger version
Old 09-09-2019, 04:58:01 PM
I looked on the crank shaft ends and didn't see anything stamped there. Is there any place else the serial number could be?
Old 09-09-2019, 05:23:53 PM
Some Sattley engines have cheap white metal name tags which often detoriate to the point that you can not read them. The tag on your engine appears to be a brass tag and it should clean up nice, revealing the serial number which should be a 5 digit number.
Denis Rouleau
Feild & Brundage / Racine Sattley BobRR Hit & Miss Gas Engine Discussion 63 05-09-2019 10:43:44 AM
Sattley, Field Brundage what can you tell me? Will Batty Hit & Miss Gas Engine Discussion 9 01-30-2019 09:54:00 AM
Field Brundage, Racine Sattley, OR BOTH? greenmars2 Antique Engine Photos 4 04-29-2016 01:04:50 AM
1 1/2 hp Sattley (Field-Brundage) repops? Eric McKenna Hit & Miss Gas Engine Discussion 0 07-11-2015 07:06:05 PM
Indentifying a Field Brundage / Sattley Harry Hit & Miss Gas Engine Discussion 9 08-07-2008 02:17:36 PM
