"A" Prefix Engine Water Pump I.D.
this thread has 1 replies and has been viewed 437 times
Old 12-24-2018, 11:23:18 AM
rhb-3 rhb-3 is offline
Default "A" Prefix Engine Water Pump I.D.
I recently have come across this old water pump assembly from what looks to have been a tractor engine. There are part numbers that all start with an "A". The gear drive section has, A-8584, Water Pump A-73027 or A-13021, water inlet or outlet A-3028. Hope there may be someone who can I.D. this pump as I'm sure someone needs it and I would hate to see it scrapped.
ID:	325035   Click image for larger version
ID:	325036   Click image for larger version
ID:	325037   Click image for larger version
Old 12-24-2018, 03:16:33 PM
Craig Gillingham Craig Gillingham is offline
Default Re: "A" Prefix Engine Water Pump I.D.
It's off an early Dodge 4 car, the pre 1927 type. Although I'm not sure exactly what year it suits.
The Following 2 Users Say Thank You to Craig Gillingham For This Post:
"Paul Watering Systems" water pump? 68Futura Small Air Cooled Gasoline Engines 25 09-29-2015 01:42:23 PM
New Brass water pump 2" X 1-1/2" going to scrap 20 Reeves Highwheeler Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 11-09-2014 08:56:05 AM
Is this a "Case" water pump? Rick Schmitz Farm Antiques and Collectibles 4 02-07-2012 10:26:05 PM
F-M "Typhoon" water pump Rick Strobel Hit & Miss Gas Engine Discussion 7 10-08-2011 12:19:39 PM
Lucas water pump "PRESSURE" Relief Paul Spence Antique Engine Archives 4 08-30-2001 06:40:08 PM
