1/3 Scale (Oil Pull) Tractor
this thread has 7 replies and has been viewed 884 times
Old 05-06-2019, 03:08:37 PM
clodiphobia clodiphobia is offline
Default 1/3 Scale (Oil Pull) Tractor
Trying to finish up my tractor. Need to find 10 spline universal joint to connect gear box and drive shaft.
Any info would be appreciated.
ID:	334265   Click image for larger version
ID:	334266   Click image for larger version
The Following 10 Users Say Thank You to clodiphobia For This Post:
Old 05-06-2019, 11:18:24 PM
ulgydog56's Avatar
Default Re: 1/3 scale (oil pull) tractor
very nice work...
Old 05-07-2019, 06:29:41 AM
dndkorn dndkorn is offline
Looks good. You may want to check with an Ag supply store that sells tractor PTO parts. If memory serves me correctly a 540 rpm pto on a farm tractor has 10 splines and is 1 1/2 inches in diameter. That might work. Good luck
Old 05-07-2019, 08:43:34 AM
Steve Kunz's Avatar
Nice looking tractor! Yes I would check with an Ag supply, or this place- The U Joint Store
http://theujointstore.com/?gclid=Cjw...BoCzKoQAvD_BwE
Steve Kunz
The Following User Says Thank You to Steve Kunz For This Post:
Old 05-07-2019, 10:04:02 AM
Tracy T Tracy T is offline
nice job! I think steve has turned you onto a source. may have to give them a call though, I know i would need to!
The Following User Says Thank You to Tracy T For This Post:
Old 05-16-2019, 09:55:18 PM
Thanks for the update. Can't seem to find what I need. One end is 10 spline other is smooth, no spline just a key way
Old 05-17-2019, 05:36:45 PM
b7100 b7100 is offline
Default Re: 1/3 Scale (Oil Pull) Tractor
You don't state the diameter. You can get 10 splined couplers from Grainger. Maybe bore out a universal joint and weld in a coupler. Or contact a driveshaft shop to see if there is such a thing. Tsc has pto drivelines. Can't remember the brand but google the name and contact them to see if they have or can get such a thing. Any chance of switching the splined shaft to a keyed shaft?
Old 05-17-2019, 10:35:46 PM
Ifix71 Ifix71 is offline
Try Hub city, agricultural products they have an assortment of spline adapters that you might be able to use
John
1/4 scale Rumely oil pull value? jesters13 Scale Model Engineering 11 06-27-2017 08:05:45 PM
Oil Pull Scale Model/Titan Tractor Model Gary Bahre Hit & Miss Gas Engine Discussion 3 10-06-2016 06:18:25 AM
Scale Model Oil Pull gbpacker3921 Scale Model Engineering 11 06-23-2014 11:54:27 AM
Case 1/2 Scale Full Pull Jeff Smith Steam Stationary Engines, Traction Engines 3 08-29-2012 11:46:14 PM
scale rumely oil pull hand crafted by Wayne G. Waldie tim w Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 06-02-2007 10:30:30 PM
