Briggs Model Q Teardown
this thread has 37 replies and has been viewed 1211 times
Old 06-11-2019, 08:09:51 PM
Mike Stroz Mike Stroz is offline
Default Briggs Model Q Teardown
Just picked up a pretty nice Briggs Model Q, serial number in the 5000's, and it seems like it's been sitting so long it's rusted up inside. It turns over but it's a little crunchy. Never seen a Q before, what's the procedure to get it apart? I can see the base unbolts but I haven't done anything but pull the head to reveal some somewhat crusty valves
Old 06-11-2019, 09:03:52 PM
Default Re: Briggs Model Q Teardown
I have a rough but fairly complete Q.The flywheel was run loose and ruined the flywheel and crank.I have only got a glimpse of it in the past 10 years as it is on a shelf in behind a couple B's and some other stuff.
I had no idea they were scarce when I paid 75 bucks for it 20 years ago.I thought I could scratch up a crank and flywheel easy and cheap. I have not looked that hard but have not seen any just laying around.
Old 06-11-2019, 09:21:08 PM
I can imagine parts are hard to come by. This one seems to be in good shape which is why I'm even trying to save it. The cam isn't wiped out and it has good compression. I'm thinking it was just stored in a humid place for a bunch of years without any oil circulating to keep the rust at bay.
Old 06-11-2019, 09:50:45 PM
Vanman Vanman is online now
How bad are the flywheel and crank? I'd think a repair could be effected. Even if it means machining a tapered sleeve...
That's pretty cool. I don't have anything that rare. Some ZZs, a B, a WMB. Do have a water cooled Z / ZZ that's pretty neat
Keith
Old 06-11-2019, 10:06:37 PM
Not meaning to highjack but it is my K I would really like to get running.It is close but never hit a lick.
I don't know when I will get time in the near future to dig that Q out. Maybe I should.
Old 06-11-2019, 10:52:24 PM
K-Tron K-Tron is offline
With any valuable, rare old engine, it is best to be as gentle as you can with disassembly. I have submerged many stuck engines in my ultrasonic cleaner and pulled out clean free engines. This process strips paint, so it may not be for you. I'd suggest using plenty of pblaster or kroil to help you disassemble the engine for proper inspection. I would not run an engine of that age without first pulling the piston and rod to check for stuck rings.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 06-11-2019, 11:14:19 PM
Mike in NC's Avatar
Vanman- Any water cooled Briggs are uncommon!
Uglyblue66- bring your engine to the Boone this summer to the show.
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Old 06-12-2019, 08:51:42 AM
Which 1? the Q or the K?
Old 06-12-2019, 10:28:13 AM
Mike in NC's Avatar
Which ever you would like, or even both of them. Bring a whole load. The more the merrier!!
SmokStak Member #28
Old 06-12-2019, 01:44:25 PM
I think I'm going to do a minimal teardown of the internals and hopefully get all the rust cleaned up. I'll probably open it up, pull the piston and rod, and the valves, but leave the rest together because I feel like I'll break something if I go too far. Does anyone know the correct torque for the rod bolts?
Old 06-12-2019, 04:36:10 PM
Mike in NC's Avatar
Looks like 190 in/lbs.
SmokStak Member #28
Old 06-12-2019, 07:37:54 PM
Perfect, thanks.
I just tore into it, did a valve job, cleaned the sludge out of the bottom end, honed the cylinder, etc. and I only realized the issue when I was putting it back together- the rod was snapped at some point and someone brazed it back together! Looks like it ran low on oil, seized, and broke the rod at the crank. No other damage or botched repairs to speak of, but it looks like I need a new rod if anyone has one. I'm not entirely confident the one in it is original but it says 652/6-2, the / may be a 7 but it's really hard to tell. If anyone has one my crank measures 0.999"
Old 06-12-2019, 08:20:44 PM
Here is my Q. It took me about 30 minutes to dig it out!
Serial number is 1747
It has a Tillitson carb with it. Or it slides onto that peice on the engine anyway? I am purty sure it was on it when I got it.Tightens with a screw and nut.
it appears to have been painted orange along time ago.
it is not stuck,but I could not turn it enough to see if it had compression. The keyway is wallowed out and I want to say the taper is worn.I will have to hunt a bit more to see if the nut and all is handy for it,I felt lucky to find what I did for it.It has been here over 20 years and has been on the shelf as you see purty much since 2006.
The Following 4 Users Say Thank You to uglyblue66 For This Post:
Old 06-12-2019, 08:25:39 PM
That doesn't looks too bad, mine is only missing the air cleaner and it was painted black, silver, red, green, and yellow for some reason. I bought it, a WA, a Y (I think), an LA, and an H parts motor for $250 a couple days ago including a couple boxes of NOS rings, pistons, valves, and a couple rods that unfortunately won't work for me..
The Following User Says Thank You to Mike Stroz For This Post:
Old 06-12-2019, 08:47:52 PM
Mike in NC's Avatar
Man did you get a deal!! The WA is not common.
SmokStak Member #28
Old 06-12-2019, 08:57:02 PM
I thought so! I'm probably going to be selling the WA since I have the very similar Q but I'll see if I can get it going first. It's really clean but no spark, I'm thinking the condensor on it is bad.
Old 06-12-2019, 09:26:44 PM
Mike in NC's Avatar
How much for the WA?
SmokStak Member #28
Old 06-12-2019, 09:52:58 PM
No idea, I've never seen one before
Old 06-13-2019, 08:39:23 AM
Looks like the part number for the rod I need is actually 66339, I'm not sure where the rod I have came from but it's definitely not for this motor. Maybe it's one that originally didn't have the oil splasher on the end but it was added?
Old 06-13-2019, 07:50:37 PM
I'm starting to think I might sell my Q as parts and keep the very similar WA, which I did get to pop a few times today and will be much less work.
Model 82 Teardown Question kleinkaliber Maytag Engines and Collectibles 2 12-06-2015 12:52:25 PM
Little crawler teardown wilson Ross Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-26-2010 01:09:21 PM
Cam timing after teardown gruby26 Small Air Cooled Gasoline Engines 3 01-18-2009 09:21:11 AM
Tecumseh H30 teardown and overhaul squarend Small Air Cooled Gasoline Engines 9 05-10-2008 11:35:27 PM
