Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Railroads and Equipment
Railroads and Equipment Vintage Locomotives, Vintage Railroads and Cars, Equipment and Lore
My new engine: Fairmont
this thread has 2 replies and has been viewed 340 times
Old 06-30-2019, 09:20:09 PM
johnnyrock70 johnnyrock70 is offline
Default My new engine: Fairmont
Dont know much about em yet, but I'm reading old threads and internet research. I'm gonna have fun with this old girl. I think it is a 1958 (but not positive yet). Magneto is an Eisemann.
ID:	338289   Click image for larger version
ID:	338290   Click image for larger version
ID:	338291   Click image for larger version
The Following 3 Users Say Thank You to johnnyrock70 For This Post:
Old 07-01-2019, 06:34:59 AM
WildIrishman52's Avatar
WildIrishman52 WildIrishman52 is offline
Default Re: My new engine: Fairmont
The belt pulley "had" an outer lip on it to keep the flat belt on. I would take a flap wheel and smooth up those edges, that could be nasty if someone's leg rubbed up against that if the engine was running!
Old 07-01-2019, 02:32:34 PM
Cant read the tag, but it looks like an ROC.6 HP. 16:1 oil mix using SAE 40 NON Detergent. You can get away with SAE 30 if you dont load it hard. TCW-3 OIL will work too. DONT cut the mix to 20-1, I have seen too many engines burned out by peope doing that! The 'muffler was a piece of 11/2 tubing (NOT PIPE), with the end squashed 1/2 flat. The engine needs a little back pressure to run right. unusual to see a mag on the fairmont! They usually ran on battery and coil, and moving the timer allowed you tio reverse the engine. Shouldnt be able to do that with a mag, as they usually aredirectional The 'radiator' is actually a condenser, that turns steam back into water to save down time refilling the hopper. DO NOT run the engine without water in the hopper. if you do, you may crack the cylinder or damage the hopper due to thermal expansion. Use water only, NO antifreeze. Antifreeze makes the engine run too hot, and breaks down to a caustic solution that will damage the aluminum hopper (galvanic action between iron and aluminum.).
The Following 3 Users Say Thank You to Andrew Mackey For This Post:
Fairmont Gas Engine 4hp Robert Beer Unidentified Engines 3 04-26-2017 05:59:43 PM
Fairmont ROC Engine polaschd Hit & Miss Gas Engine Discussion 4 02-12-2015 01:31:12 PM
Fairmont engine R. Kern Hit & Miss Gas Engine Discussion 5 12-11-2008 11:53:42 PM
Fairmont engine help Ron Jeskey Hit & Miss Gas Engine Discussion 2 12-08-2008 05:01:32 PM
Fairmont: new engine? Brickman Hit & Miss Gas Engine Discussion 6 05-04-2006 11:32:32 PM
