Pierce Inverted Twin, surface carburetor
this thread has 37 replies and has been viewed 2503 times
Old 08-09-2019, 06:21:35 AM
Gemmer1 Gemmer1 is offline
Photo Re: Pierce inverted twin, surface carburetor
Bill, it appears that the combustion chamber could be opened to the atmosphere, cylinder drain?? But I don't see why.
Another thing I noticed is what looks like an intake valve with a spring on the left hand port. The smaller HP engines used the right port for the intake and the left one was just an access to the exhaust valve on the other side of the cylinder. See pic.
Also a couple of 2HP catalog pictures.
Jim
ID:	341062   Click image for larger version
Name:	Pierce 2 HP.jpg
ID:	341063   Click image for larger version
The Following 7 Users Say Thank You to Gemmer1 For This Post:
Old 08-09-2019, 08:59:32 AM
Default Re: Pierce inverted twin, surface carburetor
This engine was cobbled together bad, the spring on the left hole is a home made intake valve cage as well as the plug where the intake belongs. They put a hole in the base and drilled a hole into the combustion chamber for a spark plug and when drilling the hole they hit the water jacket and to stop the water from running out they poured lead all around the spark plug hole to seal it up. It was a mess.
I was able to gain access to the engine at the Henry Ford Museum and take measurements and pictures so I can make the engine right. Their engine is also missing parts but between the two and the catalog cuts I should be able to make the parts it needs. I am making the exhaust plug, intake cage, fuel pump and rod, overflow bowl, ignitor, mixer and pulley.
The Following 4 Users Say Thank You to Bill Hazzard For This Post:
  #23
Old 08-09-2019, 09:06:40 AM
Chris Epping's Avatar
Chris Epping Chris Epping is offline
Bill - is this the same engine before you removed the colorful paint?
The Following 4 Users Say Thank You to Chris Epping For This Post:
  #24
Old 08-09-2019, 09:08:21 AM
Dale Russell Dale Russell is offline
Sounds like you got your work cut out for you. Good luck!
Old 08-09-2019, 10:30:12 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
I think I have seen that pink engine before, maybe at Pawnee, OK about 20 years ago.
This thread has got me excited about my twin again. It has not been out since Coolspring two years ago. If I live long enough I would like to be able to get a period correct boat built to install it in. Anyone have any literature on the style of boat it would have been in?
The Following User Says Thank You to Dwayne Fuller For This Post:
  #26
Old 08-10-2019, 05:28:03 PM
saengineman saengineman is offline
It was at the big Granbury show a long time ago.
Old 08-10-2019, 09:04:39 PM
Chris, yes that is the engine that I am working on, thankfully Jerry sand blasted that paint off.
  #28
Old 08-12-2019, 10:14:33 PM
I made a new platform, finished the plumbing. I have to square everything up and bolt it down. I should be ready to run in a few days.
Name:	pierce plumbing 1.JPG
ID:	341296   Click image for larger version
Name:	pierce plumbing 2.JPG
ID:	341297   Click image for larger version
Name:	pierce plumbing 3.JPG
The Following 12 Users Say Thank You to J.B. Castagnos For This Post:
  #29
Old 08-12-2019, 11:28:35 PM
Lester Bowman Lester Bowman is offline
JB..
I really cannot make out the plumbing very well but do see your Gas Cocks. If you haven't an inline Check Valve coming off your vaporizer you certainly should install one at least AND a fitting with a "flash back" screen pack.
Wayne Grenning had an EXCELLENT thread on these types of Flash Back screens and I tried my best to find it but failed. Remember in High School lab and the experiment where a screen was held above the flame of a Bunsen burner? The flame would stay on the bottom of the screen..the screen preventing it from going through the fine weave of the screen.
What you NEED to remember about these vapor systems is this. That fuel mixture coming from that cast iron tank is a volatile mixture of fuel AND AIR . In other words a flame can flash back through the piping because it has enough oxygen mixed with it to do so.
You know more than I about these Pierce Vaporizers. However I see no difference in theory from a Regan Vaporizer and I know first hand that a flash back happened in a Regan Vaporizer with no check valve in place. There was an explosion involved and fortunately nobody was hurt. It was an excellent learning experience when I built my smaller Vaporizer.
I don't know.. I find a cast iron tank full of ignitable gas a bit scary and yes..you may have some "checks" in place which will do the job. I know you're not finished yet with the plumbing. Just my two cents based on experience.
By the way..wonderful job so far on an engine I always found interesting and unusual and very desirable. Well done
The Following 7 Users Say Thank You to Lester Bowman For This Post:
  #30
Old 08-13-2019, 06:38:39 AM
Excellent craftsmanship JB! That will make one very nice display.
I second what Lester is saying about the flame arrestor issue but that along with a good check valve should make it safer than what Andrew Pierce did.
Proceed carefully,
Jim
The Following 2 Users Say Thank You to Gemmer1 For This Post:
  #31
Old 08-13-2019, 06:56:56 AM
Don Selmer Don Selmer is offline
J.B. First of all what a Fantastic restoration on a rare piece. In post #4 that is my PIERCE engine. Also the 2nd picture (illustration) in that post both shows the check valve in line. Just saying. By the way I really like those brass fittings on your engine.
The Following User Says Thank You to Don Selmer For This Post:
  #32
Old 08-13-2019, 08:09:09 AM
The check valve is inside the box, I ordered some 3/8" sintered bronze filters, when they come in I'll post pictures of them in place.
The Following 3 Users Say Thank You to J.B. Castagnos For This Post:
  #33
Old 08-13-2019, 04:54:46 PM
J.B. That sounds like a true ENGINEER thinking outside the box or should I say inside the box (Surface carburetor.)
  #34
Old 08-13-2019, 07:01:30 PM
Don the fittings were mostly Chinese, had to get rid of the Chinese lettering so I cut them to make them look like the old fittings. I made a cutter to do the beads, machined what I could and sanded and polished the rest. In the last picture you can see them in various stages. The reducer on the carb was a regular cast iron fitting. When I get the flame arrestors I will post pictures and explain why the check is in the box.
ID:	341382   Click image for larger version
ID:	341385   Click image for larger version
Old 09-08-2019, 10:15:51 PM
J.B., How did your PIERCE TWIN run on the surface Carburetor at Portland?
Old 09-08-2019, 10:37:23 PM
It ran good Don, a little sensitive but I learned what it wanted. I'll get some picks and tell the rest of the story.
Old 09-08-2019, 11:35:31 PM
Default Re: Pierce Inverted Twin, surface carburetor
Were you able to get with Ed and Nick Rowland?
Old 09-09-2019, 11:22:21 AM
I saw Ed passing, didn't see Nick
Casting of Pierce Surface Carburetors Gemmer1 Hit & Miss Gas Engine Discussion 7 08-18-2019 08:35:24 AM
Inverted Pierce #2 J.B. Castagnos Hit & Miss Gas Engine Discussion 1 04-26-2015 08:29:29 PM
Pierce inverted twin J.B. Castagnos Hit & Miss Gas Engine Discussion 8 03-02-2014 07:27:12 PM
Circa 1895 Inverted pierce Mike O Hit & Miss Gas Engine Discussion 22 06-28-2009 10:26:53 AM
Pierce inverted engine Ray Webb Antique Engine Archives 9 01-07-2003 02:19:36 AM
