IHC Mogul 2.5hp Fuel pump removal
this thread has 3 replies and has been viewed 312 times
Old 08-15-2019, 10:37:39 AM
hotrodzz4 hotrodzz4 is offline
Default IHC Mogul 2.5hp Fuel pump removal
I am needing to remove the fuel pump from a 2.5 Mogul for rebuild. Is it necessary to remove the flywheel to do so? I must be overlooking something obvious but i do not see how to get the bolts out with out pulling the flywheel and the cam eccentric. Thanks for any insight!
Old 08-15-2019, 12:07:02 PM
Default Re: IHC Mogul 2.5hp Fuel pump removal
One my 1 hp it required flywheel removal to get the fuel pump off I believe. For the 2 1/2 hp its probably the same.
The Following 2 Users Say Thank You to Kevin Weis For This Post:
Old 08-16-2019, 12:29:24 AM
Turbo's Avatar
Turbo Turbo is offline
Yes the flywheel and cam must be removed before the fuel pump. Which means two gib keys!! You got to love Mogul’s. ��
Old 08-16-2019, 02:47:24 AM
Merv C Merv C is offline
The 1 hp doesn't have to have the cam removed There is enough room when the cam is in the right position. I have just done that on my 1 Hp Although I haven't removed the pump off my 2 1/2 for a long time I think it is the same.
Merv.
1hp Mogul Fuel Pump mmtractor1950 Hit & Miss Gas Engine Discussion 2 04-10-2016 08:50:12 AM
IHC 1 hp Mogul fuel pump? Kevin Weis Hit & Miss Gas Engine Discussion 3 05-31-2014 08:51:35 AM
IHC M fuel pump removal help needed Kevin Weis Hit & Miss Gas Engine Discussion 7 10-03-2011 04:39:53 PM
IHC M fuel pump removal Tilinghast Hit & Miss Gas Engine Discussion 6 09-18-2007 09:55:06 PM
Ihc 3hp m fuel pump removal Derek Meyn Hit & Miss Gas Engine Discussion 12 01-26-2006 08:16:16 AM
