Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Hardware
Hardware Nuts, Bolts, Washers and Miscellaneous Fasteners
Hardware
What are these nuts called and are they replaceable
this thread has 7 replies and has been viewed 845 times
Old 08-19-2019, 09:48:00 PM
uglyblue66 uglyblue66 is online now
Default What are these nuts called and are they replaceable
This is a really decent seat that fits the Wheel Horse A-60 I have. I want to use it BUT 3 of the nuts are missing out of the bottom of the seat.1 fell out rusted and it appeared to have some clips to lock it in or something.BUT if these are replaceable,I need to know the correct name for them so I can find them. Thanks for the help.
This pic shows 1 of the nuts in it's place to the right,and the left 1/2 inch square hole is where another should go.
Name:	DSC00032 (Medium).JPG
Old 08-19-2019, 10:03:53 PM
Jake Jacobs Jake Jacobs is offline
Default Re: What are these nuts called and are they replaceable
Google weld nuts(Granger) or captive nuts. This will get you started.
The Following User Says Thank You to Jake Jacobs For This Post:
Old 08-19-2019, 10:28:42 PM
Look at the snap in nuts at mc master carr
Old 08-19-2019, 11:01:55 PM
Thanks folks! got the info I needed thanks to you alls help.Now I just gota determine 1/4 or 5/16ths before I order them.
20 bucks is alot for 12 nuts BUT the cheapest I can get a low back seat for the machine is about 45 so to have it's original seat with the horse logo on it for 20,and have the spares,I guess it will be worth it.
https://www.ebay.com/itm/The-Hillman...gAAOSwFYJbxIXH
Old 08-20-2019, 05:14:47 PM
OTTO-Sawyer's Avatar
If it wasn't for the big square hole to fill I'd go with the "Riv-Nut" or "Nut-Sert" pop-rivet style nut insert.
With that big hole I'd probably just spot-weld a nut to it and call it done.
Old 08-20-2019, 05:54:05 PM
Any chance you could put a carriage bolt from the top with a fender washer and regular nut on the bottom? just thinking
Old 08-20-2019, 09:08:30 PM
That is a maby.OF all things I forgot to check to see what size I need as far as 5/16 or 1/4. I have been under the hood of my dads old Dodge truck Again most of the day.
Old 09-28-2019, 07:26:22 PM
Well Otto,You had the best idea and that is what I wound up going with.Turns out the holes were cracked around them.So I welded square nuts to the seat .I took the cushion off and put the seat in the electrolosis bucket for a week and the cracks showed up.I found 4 of the nuts like on ebay from a old treadmill I took apart.They fit very loose in the holes and didnt appear they would grip well.So the seat is done and painted.Now 1 of these days I will fix the machine it fits.My plans have been put off by not having much room in the shop right now and not getting my storage box.
What's it called? Deerlope Oilers, Lubricators and Grease Cups 2 09-18-2017 10:55:59 AM
This would be called? opus Onan Generators 10 08-22-2016 01:11:42 PM
What is this called, and where can I get one? packrat56 Hit & Miss Gas Engine Discussion 2 11-19-2011 09:09:40 PM
Anyone know what this is called? WilliamInOz Smokstak Down Under 2 05-25-2009 03:16:06 PM
