The Mc Vickers is home
this thread has 49 replies and has been viewed 4746 times
Old 08-30-2019, 10:39:05 PM
Chuck Foster's Avatar
Chuck Foster Chuck Foster is offline
Default The Mc Vickers is home
Well I got a 2 h.p mc vickers engine from Hoggan Henessey and with the help of Shelby Babcock and Bob Balhous , it is finally home. THANKS GUYS.
Now the work/fun begins .
It needs a cylinder head and the valve box and the exhaust lever and push rod.
Now would anyone have any of these parts???
If not can anyone supply me with pictures of said parts???
Thanks for any help you might have and I hope to post pictures as the work progresses.
Chuck
ID:	342685   Click image for larger version
ID:	342686   Click image for larger version
ID:	342687   Click image for larger version
Old 08-31-2019, 10:20:12 AM
Len Spoelman Len Spoelman is offline
Default Re: The mc vickers is home
What is in the pail? What else did you get? Carb? Does not look much different from when it left here. Best wishes on the project!
ID:	342697   Click image for larger version
ID:	342698   Click image for larger version
The Following 3 Users Say Thank You to Len Spoelman For This Post:
Old 08-31-2019, 10:13:49 PM
Thanks for the pictures Len, how long ago were they taken?
The first picture I posted shows " what's in the pail "
I will have to bore and sleeve this one as there are some deep pit mark's in the cylinder.
The other pictures show a few things I have done so far.
I hope to make temporary skids for it tomorrow.
Lots of work to do but I would like some pictures or rough dimensions of the cylinder head and valve box if possible.
Chuck
ID:	342729   Click image for larger version
ID:	342730   Click image for larger version
ID:	342731   Click image for larger version
The Following 6 Users Say Thank You to Chuck Foster For This Post:
Old 09-01-2019, 11:17:24 PM
Yup! Looks familiar. Pictures were taken 2005 here. I do not remember history before that. Loooong term project! Good to see new efforts on it.
ID:	342829   Click image for larger version
Old 09-01-2019, 11:20:13 PM
Got a bit more work done today.
I have a question about the piston , as you can see in the picture there are some holes in the piston top.
Is there something that bolts to the top of the piston to trip the ignitor??
The second picture shows the start of the connecting rod bolts .
The third picture shows the " hole " in the front of the engine base ( wonder how that happened )
And the last picture shows the cardboard template that I will use to make the steel patch .
I am going to try stitching the patch into the base as opposed to welding it in .
Never tried the stitching method but i can't weld to save my life so i will give it a try.
Chuck
ID:	342825   Click image for larger version
ID:	342826   Click image for larger version
ID:	342827   Click image for larger version
The Following 3 Users Say Thank You to Chuck Foster For This Post:
Old 09-02-2019, 07:48:40 AM
Keep jogging my memory. I think it had a wedge on the piston to make it a wood splitter. That may explain the hole in the base, yes?
The Following 2 Users Say Thank You to Len Spoelman For This Post:
Old 09-02-2019, 09:02:04 AM
Dwight Vivas Dwight Vivas is offline
Yep, the piston is tripped by a short bolt on top of the head, the 2 larger holes probably were drilled for a wedge, if the engine was used as a log splitter
The Following 3 Users Say Thank You to Dwight Vivas For This Post:
Old 09-02-2019, 04:50:59 PM
Got some more work done today.
Connecting rod bolts are all done except for the final length.
The second picture shows taping the two larger holes in the piston top.
The third picture is the short studs that I threaded into the piston top with a bit of j.b weld to help seal and hold the stud ( studs are bottomed out on there threads).
The last picture is the studs installed and waiting to be cut off to length.
Thanks to guys like Len and Dwight I have got some information to help with this restoration.
Chuck
ID:	342885   Click image for larger version
ID:	342886   Click image for larger version
ID:	342887   Click image for larger version
The Following 4 Users Say Thank You to Chuck Foster For This Post:
Old 09-02-2019, 08:42:44 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Best I have right now
Jonathan on Brians account...
ID:	342909   Click image for larger version
The Following 5 Users Say Thank You to Sad Iron For This Post:
Old 09-02-2019, 08:48:19 PM
The work continues, studs screwed into top of piston are machined off flush with the top of said piston.
Ring grooves are cleaned out and waiting for new rings.
The only paint I can find on it is on the connecting rod and it appears to be silver.
Had to remove the pipe that joins the carb. To the head.
It was stuck in there real good so I grabbed it in the mill and plunge cut a slot in the pipe till it could be collapsed. Then out it came.
Still in need of some measurements, such as the head thickness and the valve box thickness.
Chuck
ID:	342905   Click image for larger version
ID:	342906   Click image for larger version
ID:	342907   Click image for larger version
Old 09-02-2019, 08:54:43 PM
Most parts are primed now and for the most part I am done till next weekend ( work gets in the way of ALL the fun )
Thank you for the pictures Jonathan , you guys don't happen to have one of these engines do you ?
Chuck
ID:	342911   Click image for larger version
ID:	342912   Click image for larger version
The Following 5 Users Say Thank You to Chuck Foster For This Post:
Old 09-04-2019, 07:21:54 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is online now
Default Re: The Mcvickers is home
Perhaps of some interest here, some McVickers/Alma pages I made some time ago: http://buzzcoil.brinkster.net/almamc...0000index.html
Included in these pages is a McVickers/Alma registry. If you have an engine to register you can send me an email.
Denis Rouleau
The Following 2 Users Say Thank You to Denis Rouleau For This Post:
Old 09-04-2019, 01:01:46 PM
Mike Lucius's Avatar
Mike Lucius Mike Lucius is offline
Chuck
They have a piston trip ignitor. I've owned a couple of them, a 4 and a 6 HP. Both just had a bolt to trip the ignitor. Good luck with that project. It looks like it's going be a nice engine.
The Following 2 Users Say Thank You to Mike Lucius For This Post:
Old 09-05-2019, 08:53:33 PM
Denis my engine is listed on your website and thank you for all the information that you freely share with us
Mike thank you for letting me know it is just a bolt that trips the ignitor. is the bolt adjustable from the backside of the piston or do you have to remove the cylinder head to make the adjustments?
the four pictures are just some more of the parts cleaned up and they will get some attention this weekend.
thanks
chuck
ID:	343196   Click image for larger version
ID:	343197   Click image for larger version
ID:	343198   Click image for larger version
Old 09-05-2019, 08:58:39 PM
Work on the head for this engine has begun
it is going to take some time but i will get to the end of this a.s.a.p
the big lathe at work will make the turning easy as it " likes " to take some heavy cut's when needed ......... 1" deep in steel when every thing is right
the last picture is the patch that i have cut out to be stitched into the front of the base.
chuck
ID:	343200   Click image for larger version
ID:	343201   Click image for larger version
Old 09-05-2019, 10:05:39 PM
Nice work Chuck!
Pretty sure the ignitor trip bolt has to be adjusted from the head end of the cylinder.
I was also wondering why you removed the pipe from the mixer? My mixer has the same pipe nipple, it's just a slip fit into the head, held on with a set screw.
Old 09-06-2019, 05:46:43 AM
good morning Dwight
I removed the nipple from the carb. because it had a crack right were the setscrew in the carb held it. I figured i might as well remove it now before it possibly became a problem later.
So you have one of these engines ?
Is there any way i could get a few dimentions of the valve box and cylinder head ?
Such as the width , height and depth ?
Now i might be asking too much here but i also need a picture of the lever that run's the fuel pump.
If you can help that would be most appreciated .
thanks
chuck
The Following 2 Users Say Thank You to Chuck Foster For This Post:
Old 09-06-2019, 09:26:40 AM
I can get some measurements for you, but my engine is a 3 1/2 - 4hp tank cooled, missing nameplate, so I'm sure the parts are a different size.
My engine is apart, but I think I can find the fuel pump lever
The Following 2 Users Say Thank You to Dwight Vivas For This Post:
Old 09-06-2019, 09:40:15 PM
Thank you Dwight for any and pictures of what you have.
Tonight I had to make the ignition contact and it is made mostly out of wood and I hate wood working
The first picture shows the original part that I have as a pattern. It has seen better days but it is a good pattern and it had the brass contact strip and the metal arm to hold it in place.
I started with two layers of hard maple and glued them together.
Next I turned the block of wood down to size and made it look kind of like the original.
The last picture shows the brass electrical contact.
To continue in the next post.
ID:	343318   Click image for larger version
ID:	343319   Click image for larger version
ID:	343320   Click image for larger version
Old 09-06-2019, 09:51:11 PM
The first picture shows how I cut out the wood to fit the electrical contact.
Then the mounting arm.
The last two pictures shows it all done but cleaning up my dirty finger prints.
My question to you guys is , what should I finish it with ?
Old used oil or linseed oil , after all it is going to get dirty back there on the crankshaft.
Chuck
ID:	343322   Click image for larger version
ID:	343323   Click image for larger version
ID:	343324   Click image for larger version
Vickers Steering Booster Cylinder Jeremy Williams Lifting and Loading 16 10-15-2018 10:00:07 PM
Wards Gilson 1972, W/ Vickers Hydrostatic Jack D D Garden Tractors and Mowers 2 06-28-2013 12:24:19 AM
A treasure found in my home town made in my home town lil herc Antique Marine Engines and Outboard Motors 19 01-25-2010 03:09:27 AM
Large engine - Vickers/Petter Semi-Diesel T James Ives Antique Engine Photos 7 09-05-2009 03:54:54 PM
