Fairmont Engine Identification Help Needed
this thread has 4 replies and has been viewed 385 times
Old 09-05-2019, 03:03:51 AM
Dumpster Diver Dumpster Diver is offline
Default Fairmont Engine Identification Help Needed
I just bought this engine at an auction. I was thinking there would be lots of information available from Google. Wow, was I wrong. Very little information available. A lot of expired web pages etc...
Serial # is 76997. It has a casting date on the block of 10-28-46.
What model is this one considered?
The other question I have is there was a C-5 carb with the engine. The 2 studs on the back of the block where the carb should bolt is spaced 4” apart. The mounting holes in the carb are spaced 3 3/4”. Any ideas what’s going on with tht? Thanks!
ID:	343139   Click image for larger version
ID:	343140   Click image for larger version
Old 09-05-2019, 03:08:49 AM
Default Re: Fairmont Engine Identification Help Needed
I managed to post 2 pics of the carb. Here’s the other pic I intended to post.
Old 09-05-2019, 01:50:31 PM
Hard to tell without direct pictures of the engine without that stuff on it. Front and side views are best. There should be a tag on the front of the engine hopper. Fairmonnt made several models during that time. ROC 4-6 HP, QB series 6-8 HP and others. There is a site you can contact about Fairmont - see archives for other posts on fairmont. The people there can tell you when the engine was built and to whom it was sent originally. The 1941 QBA I owned used a 12:1 oil mix using SAE 40 NON-Detergent oil. A 1946 ROC my son had used 16:1 with SAE 30. I have heard of people using modern oils in their fairmonts, but I do not recommend it, and by all means, do not cut the ratio. Parts are not easy to come by, like the common 4 cycle makes.
Old 09-05-2019, 02:37:58 PM
Thanks for the reply. Here’s more pictures. There is no tag or even a place that looked like a tag would have been installed.
ID:	343173   Click image for larger version
ID:	343174   Click image for larger version
ID:	343175   Click image for larger version
Old 09-14-2019, 07:30:23 AM
Through other sources I found out this is an RQ motor. Also found out the carb should be a C8 instead of the C5. So I’m sure finding a C8 will take some time.
Good news is that I milled out the mounting holes on the C5 and it bolted up nicely. I rigged up a fuel tank and coil and it started up! These engine are anything but tame when they run. At somewhere between 8-13 HP they have some “pop” to them and are quite lively when running on a small stand. 😁
Fairmont engine info needed MikesMarineAndDeli Hit & Miss Gas Engine Discussion 4 11-18-2018 11:08:16 PM
Fairmont Engine Info Needed midpw Hit & Miss Gas Engine Discussion 19 04-08-2010 04:44:21 PM
Fairmont engine identification ??? Doug Oldenburg Hit & Miss Gas Engine Discussion 4 10-10-2008 11:15:45 PM
Engine identification needed HBurk Hit & Miss Gas Engine Discussion 16 08-30-2008 10:25:46 AM
Help! Engine Identification Needed Jim H Antique Engine Archives 6 07-03-2002 07:18:08 AM
