1914 Economy 5E changing speed
this thread has 4 replies and has been viewed 361 times
Old 09-08-2019, 08:04:16 PM
Mbetti Mbetti is offline
Default 1914 Economy 5E changing speed
A bit of a challenge but got my first hit miss running today. Tag says 425 rpm and that is about where it runs. I can move the speed lever and change rpm slightly. I tried the governor adjustment screw and came to the end of its travel to get slower. So is there a secret to slowing it down more?
Old 09-08-2019, 08:19:14 PM
Dave Nielsen Dave Nielsen is offline
Default Re: 1914 Economy 5E changing speed
Put a lighter spring in the governor. That is how you slow a Economy down. It has been a while, but I believe you just have to remove the governor weights to get too the spring. Dave
Old 09-08-2019, 08:24:12 PM
That makes sense, I take it you just match one up from something else?
Old 09-08-2019, 10:44:12 PM
Don Tomlinson's Avatar
Don Tomlinson Don Tomlinson is offline
Valve spring from an old Briggs 4 or 5 s will do nicely. Find a mower or small engine repair guy and he might just give you a couple. First you might take out the old one and see if there any washers under it and remove them. The washers were used to adjust the speed at the factory. Good luck !
The Following 2 Users Say Thank You to Don Tomlinson For This Post:
Old 09-09-2019, 09:22:20 PM
I have just gone down to the hardware store and got one about the same diameter, but a lot lighter. Dave
Sears Economy (Hercules) 1914 5HP Bump Start JF671 YouTube Old Iron Videos 1 11-11-2016 12:06:20 PM
Economy 2 1/2hp not coming up to speed jackel440 Hit & Miss Gas Engine Discussion 5 06-18-2015 12:29:26 AM
Economy, Adjusting idle speed, how too? HarleyDealer Hit & Miss Gas Engine Discussion 2 09-23-2010 02:13:57 PM
3 1/2 Economy speed regulation CLowe Hit & Miss Gas Engine Discussion 12 09-19-2007 09:41:04 PM
1914-15 Economy Ryan Slaback Antique Engine Archives 7 03-23-2004 12:08:08 AM
