Newway Tractor
this thread has 13 replies and has been viewed 1062 times
Old 09-11-2019, 10:25:08 PM
Ray Gardner Ray Gardner is offline
Default Newway Tractor
This Tractor was given to me, anyone no about them. what is the engine, can I find parts.
Ray
ID:	343796   Click image for larger version
ID:	343797   Click image for larger version
The Following 5 Users Say Thank You to Ray Gardner For This Post:
Old 09-11-2019, 10:31:16 PM
Craig Gillingham Craig Gillingham is offline
Default Re: newway tractor
I think that's actually a Centaur tractor, with a New Way engine.
The Following User Says Thank You to Craig Gillingham For This Post:
Old 09-11-2019, 10:42:10 PM
That is a early Centaur garden tractor with a new way gas engine
Old 09-11-2019, 10:44:03 PM
Doug Tallman Doug Tallman is offline
Yes, it is the remains of a Centaur F. Would have been made between mid 24 and the end of production 25/6 range. It's a NewWay model CH engine.
The Following User Says Thank You to Doug Tallman For This Post:
Old 09-11-2019, 10:47:17 PM
Sunnybrook Sunnybrook is offline
Ray, I sent you a message...my tractor is missing your sulky!
If you sell please consider me.
Thank you!
The Following User Says Thank You to Sunnybrook For This Post:
Old 09-12-2019, 08:28:02 AM
joder joder is offline
That's a very restorable tractor and you don't see many of them - the tractor part looks complete. I've got one of similar vintage and yours looks in better shape than what I'm starting with.
It'd probably be easier and cheaper to find a complete replacement CH engine as a parts donor as the one on it looks to have been stripped. Running engines pop up every now and again on Enginads or Ebay for around $350; you'll have $350 in just finding a good mag and carb separately.
The Following 2 Users Say Thank You to joder For This Post:
Old 09-12-2019, 09:37:11 AM
I'm looking closer at the cylinder - that doesn't look like a CH cylinder - the base & everything else looks right but the intake and exhaust ports are on the wrong sides, it looks too tall, there shouldn't be a fan shaft, etc. It looks like someone put a DF or even earlier cylinder on the CH base. Definitely need to replace that.
And it looks like you're actually missing part of the transmission coupling.
Last edited by joder; 09-12-2019 at 05:04:34 PM. Reason: Wrong name for the coupling
The Following User Says Thank You to joder For This Post:
Old 09-12-2019, 04:50:23 PM
Default Re: Newway Tractor
That isn't a lovejoy coupler. That should be a twin disc clutch. The only thing there is the disc and the driven piece that is mounted to the trans.
The Following 3 Users Say Thank You to Doug Tallman For This Post:
Old 09-14-2019, 07:34:55 PM
Thanks for the info, I hope to find a complete ch engine to buy, I have the clutch parts and every thing else, Its in really great shape. what year is it. I hope someone reading this will have an engine for sale.
Ray
The Following User Says Thank You to Ray Gardner For This Post:
Old 09-14-2019, 08:23:29 PM
AussieIron AussieIron is offline
I would love to own an early New Way powered centaur. Glad you decided to go ahead and restore it. Good luck with the project, should be a good one.--Cheers-Neil.
Old 09-15-2019, 09:43:34 AM
Ray
Ray, look back around where the right handlebar bolts to the frame. The tractor serial number will be found on the top of the rail, usually behind where the handle mounts. I can tell the date from that. It's going to be a 24/25 with that style clutch.
Old 09-21-2019, 12:32:05 AM
I found the serial number it is F625678 will this tell the date it was made, to th man that needs a sulky, if I sell it I will let you know.
The Following 2 Users Say Thank You to Ray Gardner For This Post:
Old 09-21-2019, 08:26:31 AM
F625678 breaks down to model F 6/25 was the mfg date and 678 was the number built in 1925. This was built in June of 25 and the 678th tractor built that year. They started over with the build numbers every year so a total production is hard to figure.
The Following 2 Users Say Thank You to Doug Tallman For This Post:
Old 09-21-2019, 11:53:53 AM
Thanks for letting me know the year, This centaur is in really good shape, hardly no wear,
Ray
Newway 3.5hp ssn647 Hit & Miss Gas Engine Discussion 23 07-03-2016 04:31:59 PM
Need help with Newway Rich Martz Hit & Miss Gas Engine Discussion 1 09-05-2009 09:30:01 PM
Tractor with NewWay engine? Firewoodguy Antique Farm Tractors 9 05-21-2008 10:45:32 PM
6hp newway upright tim rostar Antique Engine Archives 0 03-12-2004 06:06:10 PM
2 cyl newway Mike O'malley Antique Engine Archives 1 01-28-2001 09:28:08 PM
