Witte Engine Balance
this thread has 9 replies and has been viewed 507 times
Old 09-12-2019, 05:32:59 PM
Motoman Motoman is offline
Default Witte Engine Balance
I have a 1914 Witte 2hp motor. It has been in my family since new, and to the best of my knowledge has never been disassembled. It did see a lot of abuse. I have managed to get the engine running, but it jumps around like crazy. I am thinking it is somehow out of balance, but I don’t understand how. Any ideas?
The Following User Says Thank You to Motoman For This Post:
Old 09-12-2019, 05:53:18 PM
Barnbikes Barnbikes is offline
Default Re: Witte engine balance
Magneto or battery?
Sounds like a timing issue on ignition.
If it has a Wico mag which way is the retard/advance lever under the mag?
The Following User Says Thank You to Barnbikes For This Post:
Old 09-12-2019, 06:13:45 PM
AussieIron AussieIron is offline
Agree, may be timing, they will bounce around if out too far.
The Following User Says Thank You to AussieIron For This Post:
Old 09-12-2019, 06:15:23 PM
The engine has a wick mag. I was not aware that there was a retard advance lever. Is it easy to identify it?
Old 09-12-2019, 08:30:24 PM
Jeremy Hartle Jeremy Hartle is offline
Should be on the trip mechanism. Depends on what trip style you have as to where it is.
Old 09-12-2019, 08:36:17 PM
ScooterBob ScooterBob is offline
How fast is it running? Too fast will make them jump. An IHC model M engine will jump straight up and down starting about 100 rpm over rated speed. 600 rpm should be about max, the tag will tell you for sure.
The Following 2 Users Say Thank You to ScooterBob For This Post:
Old 09-12-2019, 09:53:23 PM
Foseng Foseng is offline
If you have not run it before it maybe that the flywheels are incorrectly fitted. Need a photograph so the experts can tell. I once had an engine where a flywheel had been removed and fitted the wrong way around.
Dave
The Following User Says Thank You to Foseng For This Post:
Old 09-13-2019, 02:38:51 AM
gasenginerick gasenginerick is offline
I had a 1915 2 HP headless Witte and even running just below rated speed the wheels would rock back and forth on the cart more than some of my other engines Bob is probably right; the engine is just running too fast.
The Following User Says Thank You to gasenginerick For This Post:
Old 09-13-2019, 06:18:37 AM
https://www.old-engine.com/maghma.htm
Old 09-13-2019, 07:48:23 AM
One more thought, is is sitting on solid ground or on a cart with solid wheels , or is it on a cart with air filled tires? Air filled tires are a no no.
The Following User Says Thank You to ScooterBob For This Post:
Balance Scale Greg M Farm Antiques and Collectibles 2 12-27-2016 11:59:43 AM
Engine Balance Question Jason W Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 03-02-2012 11:29:32 PM
How important is balance... really? sabre85rdj Onan Generators 22 02-12-2011 11:04:09 AM
Easiest engine to balance Casemaker Steam Stationary Engines, Traction Engines 23 08-10-2007 12:29:43 AM
Load Balance Bill Schmidt Onan Generators 2 04-09-2005 10:32:02 AM
