Witte 2 HP gas engine
this thread has 1 replies and has been viewed 296 times
Old 09-14-2019, 09:36:37 PM
wayneswenson wayneswenson is offline
Default Witte 2 HP gas engine
I have serial # 84517 engine rated at 600 RPM.
Question: What is the initial setting for the main fuel screw?
Question: Any info on setting the magneto to fire at the correct time? It seems to fire quite late when spark lever is retarded. When spark lever is in run position it fires just after TDC. Is the cam off by 1 cog?
Thank you.
Old 09-15-2019, 01:18:24 PM
stufforbud stufforbud is offline
Default Re: Witte 2 HP gas engine
I would say you are on the right track. Should fire before TDC with the lever advanced.
Engine ID Witte? 55gasser Hit & Miss Gas Engine Discussion 7 11-11-2012 09:48:46 PM
Need help with a Witte Engine fortvlly Hit & Miss Gas Engine Discussion 8 04-09-2011 10:19:32 PM
Witte Engine Frank Martin Hit & Miss Gas Engine Discussion 2 03-24-2009 10:05:24 PM
new engine 8 hp witte Brickman Hit & Miss Gas Engine Discussion 0 02-19-2007 09:51:45 AM
Witte Engine Kenny Ranta Antique Engine Archives 0 01-31-2002 09:49:39 PM
