Ideal Model R 1.5 HP Magneto version HELP!
this thread has 1 replies and has been viewed 245 times
Old 09-15-2019, 11:03:22 PM
dandaman1 dandaman1 is offline
Default Ideal Model R 1.5 HP Magneto version HELP!
I am in search for some information on my Ideal Model R 1.5 hp hit and miss. I have read the manuals which are written for the 3/4 HP version. I am wondering if there is a difference in the amount of oil that you put in the crank case? The manual for the 3/4HP model says to use 1/2 of one pint. I think mine is over filled due to the amount of smoke it puts out when it is finally starts. It only runs for about a couple of minutes before it stops. The plug is oil soaked. Also I checked the timing of the spark as well as the valve timing and it seems like they are set to specs. It is very hard to start, does anyone have any ideas on how to make it start easier? This is my first engine so I am learning. I would like anyone with advise to please offer any suggestions. Thank you! The serial number is
X29546 Has Wico Magneto. It does spark
Old 09-16-2019, 02:41:07 PM
Default Re: Ideal Model R 1.5 HP Magneto version HELP!
You want the con rod to touch the oil by about a 1/4" More than that may over oil the engine. i would look for a manual for your engine. You sre using SAE 30, yes? usually, if you overfill the engine, it will toss oil out the fine screened vent on the inspection cover. If that vent is not functionning, you could be creating pressure in the crankcase, which will cause oil pumping past the rings. Gummed up or partially stuck rings will also cause smoke, The ideals are not easy starters at best. I am assuming that the engine has a WICO EK (square box) for a mag? On start or retard, it should trip right at TDC Compression.
Ideal model C Jeff P Smith Hit & Miss Gas Engine Discussion 1 05-21-2015 01:09:56 PM
Ideal M upright Bosch magneto repair Oilzum Magnetos, Ignition Coils and Spark Plugs 2 05-27-2014 12:46:26 AM
Ideal Engine Wico EK Magneto trip springs Doug Oldenburg Magnetos, Ignition Coils and Spark Plugs 6 09-11-2012 01:37:46 AM
Ideal Model V? Alan R Hit & Miss Gas Engine Discussion 0 01-21-2006 08:55:44 PM
FAN FOR IDEAL MODEL R Dan Burkart Antique Engine Archives 0 01-15-2001 08:39:25 PM
