2 HP air cooled Famous question
this thread has 7 replies and has been viewed 735 times
Old 09-16-2019, 09:46:55 AM
junkin junkin is offline
Default 2 HP air cooled Famous question
Have a 1908 with the governor weighs inside flywheel which operates on a ring. The solid bearing that runs on the ring needs to be replaced. The steel pin that the solid bearing runs on is mounted in a brass bracket. Does anyone know how the steel pin is held inside the brass bracket, looks to be a 1/4" pin?
Thanks for any info!
Old 09-16-2019, 03:42:56 PM
Default Re: 2 HP air cooled Famous question
Here is a couple photos of the brass bracket with the roller attached with steel pin.
ID:	344176   Click image for larger version
Old 09-17-2019, 10:52:40 AM
Skip Landis Skip Landis is offline
I have an engine like yours. It is the only other one i've heard of with that type governor. Being a machinist, my guess would be that the pin is pressed in. Only a guess. skip
Old 09-17-2019, 12:45:43 PM
Thanks, I took 1/8" carbide tip and clean to where the pin was round and tapped lightly with a small punch with no luck. Maybe it needs a little heat and little more punch.
Wade
Old 09-17-2019, 09:21:40 PM
RVandervoort1 RVandervoort1 is offline
So is your governor on the cam gear or on the flywheel? Do you have more pictures of your engine and governor? What is your serial number? I have two engines here with the governor on the cam gear.
Old 09-18-2019, 01:08:55 AM
mine is on the cam gear. skip
Old 09-18-2019, 01:44:15 PM
They are on the cam gear, serial # KB146
ID:	344355   Click image for larger version
The Following User Says Thank You to junkin For This Post:
Old 09-18-2019, 04:46:20 PM
That pin is pressed in, friend of mine told me to heat the brass bracket up and let it cool and then you should be able to push it out with punch and it did. Now I can make me new roller or use a ball bearing.
Thanks Skip and RVandervoort1
The Following 3 Users Say Thank You to junkin For This Post:
Question about 6hp screen cooled Famous mikeinct Hit & Miss Gas Engine Discussion 4 01-07-2012 08:59:48 AM
IHC Famous 2HP Screen Cooled Mixer Question Handlebar99 Hit & Miss Gas Engine Discussion 11 06-22-2009 02:09:25 PM
IHC 2 1/2 hp hopper cooled famous question? Robert DeBord Hit & Miss Gas Engine Discussion 2 05-24-2009 02:58:18 PM
IHC 2 1/2 hp hopper cooled famous with magneto question? Robert DeBord Hit & Miss Gas Engine Discussion 3 03-10-2009 11:23:31 PM
IHC 6 HP Famous Tank Cooled Question John Derby Hit & Miss Gas Engine Discussion 3 06-19-2008 09:18:08 PM
