Economy 1-1/2 HP now running.
this thread has 2 replies and has been viewed 318 times
Old 09-17-2019, 04:04:23 PM
Eng42 Eng42 is offline
Default Economy 1-1/2 HP now running.
I put in a new gas tank, charged the magneto magnet, cleaned the points and got it running. It still tends to stop from time to time. There is a mesh filter that is attached to the 1/4 pipe coming out of the tank. It is inside the tank. I cleaned is best I could but still wonder about it. Did most of those old engine have a screen like that. I want to get it running real well because I am thinking of selling it, along with the grist mill. What is something like that worth nowadays. I live in Southern California.
Old 09-17-2019, 05:19:47 PM
Dale Russell Dale Russell is offline
Default Re: Economy 1-1/2 HP now running.
That would make someone a nice display. Try some Spray Carb cleaner on the screen on the fuel pickup tube. I put screens on all of my pickup tubes.
Old 09-18-2019, 01:05:12 PM
Exclamation Re: Economy 1-1/2 HP now running.
Berkbile 2 + 2 works best on old gum. Gumout is virtually worthless on the old stuff. Not sure if you can get the Berkbile produce in KS though. Here in NJ it is carried in NAPA and Carquest auto supply stores The check ball above the s. creen may also be at fault if it is pitted or sticky.
Getting it running: 3hp Economy BigGoomba Hit & Miss Gas Engine Discussion 36 09-04-2014 09:01:00 AM
Economy 9hp up and running. Craig M. Strader Sr. Hit & Miss Gas Engine Discussion 6 06-30-2013 11:10:11 PM
Help me get my 5 hp Economy running bergrider01 Hit & Miss Gas Engine Discussion 28 02-28-2010 02:10:02 PM
Economy not running right! Temple2426 Hit & Miss Gas Engine Discussion 15 11-03-2009 11:27:55 PM
Economy 1 1/2hp not running jameslee Hit & Miss Gas Engine Discussion 6 10-09-2009 05:01:13 PM
