10 20 Titan
this thread has 31 replies and has been viewed 5856 times
Old 01-15-2006, 03:02:44 AM
Dan Baalman Dan Baalman is offline
Default 10 20 Titan
Have recently acquired two 10 20 Titan tractor cooling tanks. Is there anyone in need on one? Thought about ebay but they are awful big and thought shipping would be a pain. They are both in pretty good shape. One has dents on the round end but i think they could be pounded out. The other is in great shape with gread zinc plating. Neither rusted and would both be serviceable as is. Let me know if you know of any one needing these. thanks
Old 01-15-2006, 10:39:53 AM
Robertcat Robertcat is offline
Default Re: 10 20 Titan
Dan, I would be interested and have sent you a E-mail!
Old 01-15-2006, 02:35:15 PM
Dan, there are two sizes of tanks. The 500 rpm engines used a smaller tank than the later 575 rpm engines. Dimensions would be helpful to someone needing one.
Craig
And yes, Crist does nice work!!!
Old 01-15-2006, 08:46:13 PM
Alan New's Avatar
Alan New Alan New is offline
I definitely need one if it is the earlier one. Please let me know.
Alan
Old 01-16-2006, 02:46:09 PM
Casesteamer Casesteamer is offline
Cool Re: 10 20 Titan
I have decals available if anyone is interested. If you supply the serial number I can have that made as well.
Here is my 1920 10-20 I used the original overhaul manual to identify sizes,wording etc.
I can send pictures of what they look like on mine. Files are too large to put on here.
Thanks,
Shon
Old 01-16-2006, 03:43:23 PM
Marcel P's Avatar
Marcel P Marcel P is offline
I would like to see pictures of those decals! (would need a tank too, but I think its cheaper to have one made over here than shipping cost)
Marcel
Old 01-16-2006, 05:22:25 PM
Marcel,
Email me your email address and I will send them. They are too large to post on here.
Thanks,
Old 01-20-2006, 12:19:04 PM
Thanks,
Shon
I'm giving this a bump AND the addition of some GREAT pics from Shon!!
ID:	6451   Click image for larger version
ID:	6452   Click image for larger version
Old 01-20-2006, 08:51:31 PM
FarmallJeff's Avatar
FarmallJeff FarmallJeff is offline
Hi Shon that is a real nice job that was done on that tractor i havd a 1922
I wouldbe interested in a set of decals for it thay look like a real good set.
Let me know $$.
JEFF
Old 01-22-2006, 12:38:16 AM
I am asking $125.00 for the set Plus shipping. If you provide me with your serial number I can have the decal that goes on the right frame rail made specific for your tractor.
Not visible in the pictures is the tank level decal that goes on the back of the water tank.
Old 01-25-2006, 08:33:28 PM
Hi Shon i was just checking to see if you recived my email about the decals.
JEFF
Old 02-26-2006, 10:08:49 PM
Jimmy Brown Jimmy Brown is offline
Thanks,
Shon
Do you have 10-20 Titan decals for sale? I have an early one. Let me know.
Thanks,
Jimmy Brown
Old 03-10-2006, 09:00:15 PM
Hi Jimmy and the rest of the Titan guys i just bought a set from Shon and let me tell you there 1st class. If you need a set his are the best ones i have seen anywhere.
JEFF
Eastford CT
Old 03-12-2006, 04:08:30 PM
Thanks Jeff,
If you need any pictures or anything on where they all go I can send them to you. You can see where most go in the pictures on here, but the one for the oil levels and the water tank level are not visible.
SHon
Old 03-12-2006, 06:47:27 PM
Shon's gear cover is fabulous too................... ...............IF you need one ASK him.
Craig
Old 03-12-2006, 08:21:44 PM
Hi Craig the only other major part i need is and air cleaner, i have the cast pice that attaches to the intake just no sheet metal for it.and drive chains other than that it just about complete,and both fenders and gear cover are mint.
Jeff
Old 03-12-2006, 08:24:52 PM
Hi Shon i should be good the book i have shows just about every one and there placement.
Thanks again.------------------------
JEFF
Old 03-13-2006, 12:27:52 AM
Jeff,
The Drive chains are the same size as those from an L or LA Case. If my memory serves me right they are different size in each. the L's are shorter.
If you get combine a chain from an L and one from an LA you only need to remove about 2-4 links for the correct length. I had to do that with mine.
Unless you want to by new at $30+ per foot. If memory serves me it came out to 30 somthing feet and you have to by 10 foot lengths.
Be sure to post some pics when you get your Titan complete..
Best of luck.
Shon
Old 10-28-2010, 03:48:54 PM
Todd Osborne Todd Osborne is offline
Can some one post the actual chain size for a Titan or its description as I would ask for it at an engineer’s supply shop. From the above post it sounds like I need 2 at 15 feet?...The tractor is 1919. Thanks
Old 10-28-2010, 09:15:57 PM
Exclamation Re: 10 20 Titan
Todd the chain is a #40 and the lenth is about 14' 6"
Jeff
Craig here: JEFFREY! WHAT did you do with your head #40? ....... ....... .......
The Following 2 Users Say Thank You to FarmallJeff For This Post:
When is a Titan not a Titan, but a "TITAN " TRACTOR? Paul Spence Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 24 03-05-2016 11:34:05 AM
1hp IHC Titan, doing one up for dad JWithers Hit & Miss Gas Engine Discussion 27 01-10-2015 12:32:28 AM
Titan 10-20 Steve Barr Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-02-2005 08:26:40 PM
Need help on 1 HP Titan Larry Anger Hit & Miss Gas Engine Discussion 6 10-06-2005 10:34:27 PM
1 HP Titan Larry Anger Hit & Miss Gas Engine Discussion 3 09-28-2005 08:19:10 AM
