Flush flywheel key removal
this thread has 7 replies and has been viewed 2097 times
Old 09-06-2006, 10:58:11 AM
Jim Sherman's Avatar
Photo Flush flywheel key removal
Just thought I'd post a couple pictures of how I removed the keys on my 1.5HP Fairbanks Morse (one anyway.... still need to use a slide hammer on the gov side key since I ran out of throw on my allthread on that side)
The only reason the flywheels are coming off is the crank has a slight bend and I'm sending it off to one of the site sponsers Craig Anderson for a little fine tuning.
I used a pice of 3/8" all thread welded to the end of the key, it doesn't take a whole bunch of weld to keep it glued to the end of the key, also the vise grips are just on loose to act as a guide and keep the all thread from walking up and out of the keyway a better collar would be easy to build so the vise grips wouldn't be needed for that.
Jim Sherman
My website
Old 09-06-2006, 01:29:14 PM
Email NOT Working
Default Re: Flush flywheel key removal
Thanks Jim,
That's worth 3000 words (plus your slight commentary) and more helpful than anything I've read yet! I will put it to use myself. Thanks again!
Kevin
Old 09-06-2006, 04:27:51 PM
Terry Beasley's Avatar
Terry Beasley Terry Beasley is offline
I just removed the flywheels on my 4HP Associated and had to drill the key to remove it. I think the split flywheels must be a little easier. The solid hub wheels had a heck of a grip on the key.
Old 09-06-2006, 04:44:54 PM
R. Goodacre R. Goodacre is offline
Many thanks for taking the time to take some pictures, they show a very good idea for the removal of these stubborn keys.
Certainly one to bear in mind if I ever need to remove the keys on my Associated Hired Man!
Old 09-06-2006, 09:05:17 PM
Photo Re: Flush flywheel key removal
Here is the slide hammer arrangement, I welded a 3/8" coupling nut to a 5/8" coupling nut so the slide hammer & welded all-thread could be screwed together.
Jim Sherman
My website
Old 09-06-2006, 09:09:28 PM
Hubs that are not split would be a little more difficult, I would think this method should work on them too provided the keys were not overly driven in. I have drilled them out in the past too and it's not much fun either.
Jim Sherman
My website
Old 09-06-2006, 09:11:29 PM
JHFoster JHFoster is offline
Why not just correct the bent crank with it in the engine?
Old 09-06-2006, 09:14:54 PM
I thought about that, using the method of jacking on the end of the crank but decided not too and go the postive way, had the keys given me a tough time (like having to drill them out) I probably would have done it in myself with the flywheels on. I have read pros & cons in the archives.
Jim Sherman
My website
Flywheel removal Oldsiron Smokstak Down Under 8 10-26-2009 09:53:33 PM
Flywheel Removal mlkmn1 Hit & Miss Gas Engine Discussion 11 07-22-2009 08:21:16 AM
Flywheel removal Greg Shipley Oil Field Engines & Related Equipment 4 05-30-2005 11:08:08 PM
Flywheel key removal Tanner Remillard Antique Engine Archives 6 05-13-2003 01:30:40 PM
flywheel removal jd_mike Antique Engine Archives 9 09-07-2001 07:39:30 AM
