Timing changes while running my 1HP Titan pump engine,
this thread has 2 replies and has been viewed 1427 times
Old 02-28-2008, 01:21:27 PM
Unhappy Timing changes while running my 1HP Titan pump engine,
and it quits , but it starts right back up. After some investigation, I found that the igniter push rod timing bushing was a bit "egg shaped" and as it turned, the timing changed . So what I did was put the bushing in the lathe and turned it to be concentric. Now it's nice and shiney as shown in the photo and needs to be put back on sometime, when it gets a bit warmer here in NJ.
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 02-29-2008, 06:29:32 PM
Default Re: Timing changes while running my 1HP Titan pump engine,
Paul;
It looks like you took a day off from flea marketing. Nice job and looks like new.
Hang in there, the next thing you know we'll be complaining about it being hot.
"DELCO DON" Southern Illinois
Old 02-29-2008, 08:06:51 PM
Donald A Smith Donald A Smith is offline
Thumbs up Re: Timing changes while running my 1HP Titan pump engine,
Good job glad you got it fixed. IT is to be 45 here in Indiana. We will send you some warm weather It is heading your way. Don I can not wait to BOY IS IT HOTTT!!! Take care see you at Portland! Don in slowly warming northern Indiana
IHC Titan engine timing Kgiffin Hit & Miss Gas Engine Discussion 3 07-08-2015 10:35:25 PM
1hp Titan Timing John Crofoot Hit & Miss Gas Engine Discussion 4 05-31-2013 06:18:46 PM
Titan camshaft timing Kevin Watson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 04-09-2010 08:53:15 PM
2 1/2 titan up and running Brian.P Hit & Miss Gas Engine Discussion 4 12-21-2007 06:45:15 PM
Timing marks on 1 hp titan Rob Charles Antique Engine Archives 2 01-30-2002 10:22:04 AM
