K341 Rebuild?
this thread has 41 replies and has been viewed 25089 times
Old 03-21-2008, 07:41:47 PM
Lead Head
Default Re: K341 Rebuild?
On my flywheel puller, there is a big bolt that goes through the middle, and pushes against the center off the crankshaft, then two bolts on the side that go to the flywheel. Should I turn the two bolts on the side, or the center large bolt?
Old 03-22-2008, 11:01:56 AM
K D Redd K D Redd is offline
Any of the above. The only thing you need to watch when tightening the side bolts is to do it equally to keep the puller straight.
Kent
Help with Briggs Model 23 engine to rebuild or not rebuild jjanitor Garden Tractors and Mowers 6 04-14-2012 03:17:44 PM
Kohler K341 Taper Coupler KirkWallace Small Air Cooled Gasoline Engines 17 04-23-2011 05:35:54 PM
Replace Kohler K341 with a 16 HP Briggs in a 916 Allis Billtheeng Garden Tractors and Mowers 9 12-18-2009 08:13:51 PM
Kohler K341 cycles between fast and slow rpm jomifo Small Air Cooled Gasoline Engines 1 08-18-2009 02:58:25 PM
Kohler K341 16HP Head Torque Specs Wheel Horse Guy Small Air Cooled Gasoline Engines 2 05-29-2009 08:44:48 PM
