Wisconsin Engines
Wisconsin carb adjustment?
this thread has 1 replies and has been viewed 9881 times
Old 05-22-2008, 03:53:51 PM
CJBennett CJBennett is offline
Question Wisconsin carb adjustment?
Does anyone know what the initial settings are on a TRA-10D. It has the bendix/zenith carb.
CJ
Old 05-22-2008, 05:14:34 PM
Exclamation Re: Wisconsin carb adjustment?
Try 11/2 turns out on the main adjustment (bottom of carb), and 1 turn out on the idle mixture, Idle speed (the one on the throttle), back off until plate cannot close any further, turn in 3 turns. Start engine and adjust idle speed to about 800 RPM. Let warm up, open throttle, and adjust high speed mixture until engine runs its best - back out 1/8 turn. Let engine idle, adjust for best running, adjusting idle speed and mixture. After each adjustment, let engine run for a minute or 2 to clear up after re-setting.
JC - Tri Fuel Carb Adjustment Ted_Cool Onan Generators 4 02-19-2008 11:15:35 PM
Carter Carb Adjustment trapshooter Antique Marine Engines and Outboard Motors 1 10-20-2007 09:01:44 AM
Maytag Carb Adjustment? bjaspud Maytag Engines and Collectibles 7 05-01-2007 12:11:37 AM
Tillotson Carb float level adjustment Backfire Kohler Generators 0 05-15-2005 03:58:55 PM
oil city carb adjustment bill mckeehan Antique Engine Archives 0 06-20-2002 08:58:45 PM
