Cam timing after teardown
this thread has 3 replies and has been viewed 1436 times
Old 01-17-2009, 03:28:59 AM
gruby26 gruby26 is offline
Default Cam timing after teardown
model-326431
type-0319-01
Code-7304021
i did a ring and valve job but left the cam in now can i get the timing right without taking the cam out? and if so how?
thanks for any help
Old 01-17-2009, 09:46:22 AM
CJBennett CJBennett is offline
Default Re: cam time
Just make sure the dimple on the cam gear is lined up with the dimple on the crank gear.
CJ
The Following User Says Thank You to CJBennett For This Post:
Old 01-17-2009, 12:16:18 PM
K D Redd K D Redd is offline
Default Re: Cam timing after teardown
Did you remove the crank when you did the ring and valve job?
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 01-18-2009, 09:21:11 AM
grub54891's Avatar
grub54891 grub54891 is online now
Did ya get it?There should be mark's on the crank and gear to line up.Waiting for the call when that thing is up and running!!
The Following User Says Thank You to grub54891 For This Post:
Timing egeschwill Magnetos, Ignition Coils and Spark Plugs 2 05-22-2008 03:06:10 PM
Tecumseh H30 teardown and overhaul squarend Small Air Cooled Gasoline Engines 9 05-10-2008 11:35:27 PM
F-M ZD Timing Bill Antique Engine Archives 0 09-08-2004 06:39:11 PM
FMZ 6hp Timing Pin, Help! KyleH Antique Engine Archives 3 09-03-2004 07:08:06 PM
Teardown to remove sludge? Orrin Iseminger Antique Engine Archives 8 01-05-2000 08:41:29 PM
